<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[how to connect to M5stack PoESP32]]></title><description><![CDATA[<p dir="auto">Using arduino ide how can I connect to the device without usb port? Is there a serial to usb adapter? Or another method such as bluetooth, ethernet or wireless?</p>
]]></description><link>https://community.m5stack.com/topic/4645/how-to-connect-to-m5stack-poesp32</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 21:20:28 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4645.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 25 Sep 2022 04:29:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to how to connect to M5stack PoESP32 on Sun, 25 Sep 2022 07:23:13 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/xha1e" aria-label="Profile: xha1e">@<bdi>xha1e</bdi></a></p>
<p dir="auto">PoESP32 is a unit and meant to be controlled via Groove serial connection using AT commands.</p>
<p dir="auto">May I ask what is the reason you'd like to modify the preinstalled AT firmware?</p>
<p dir="auto">That said,  if you look at the <a href="https://docs.m5stack.com/en/unit/poesp32" target="_blank" rel="noopener noreferrer nofollow ugc">schematic</a> you'll see J2 (Download Socket) in the bottom right corner. J2 can be used with an <a href="https://docs.m5stack.com/en/tool/usb_downloader" target="_blank" rel="noopener noreferrer nofollow ugc">USB serial adapter</a> to modify the preinstalled AT firmware.</p>
<p dir="auto">Note: J2 is internal and not populated.<br />
Note: the preinstalled internal firmware can be altered / replaced using Arduino IDE. But please be aware that restoring the preinstalled AT firmware requires the ESP-IDF build environment (which is different from the Arduino IDE). Preinstalled AT firmware source code and build instructions can be found <a href="https://github.com/espressif/esp-at" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/18712</link><guid isPermaLink="true">https://community.m5stack.com/post/18712</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 25 Sep 2022 07:23:13 GMT</pubDate></item></channel></rss>
