<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Paper I2C Doesn&#x27;t work]]></title><description><![CDATA[<p dir="auto">I am trying to use the Paper and I can't get any of the ports to work. The code I am using in below. One strange thing in this code is if I comment out M5.begin() I see the internal i2C devices but if I include it I don't see any devices.</p>
<p dir="auto">#include &lt;M5EPD.h&gt;</p>
<p dir="auto">// I2C (internal) - SDA: 21, SCL: 22<br />
// I2C (external - Port A) - SDA: 25, SCL: 32</p>
<p dir="auto">#define PortA_SDA 25                 // Port A<br />
#define PortA_SCL 32</p>
<p dir="auto">#define PortB_SDA 26                 // Port B<br />
#define PortB_SCL 33</p>
<p dir="auto">#define PortC_SDA 18                 // Port C<br />
#define PortC_SCL 19</p>
<p dir="auto">#define INTERNAL_SDA 21<br />
#define INTERNAL_SCL  22</p>
{<br />
//  M5.begin();<br />
Serial.begin(115200);</p>
<p dir="auto">Wire.begin(INTERNAL_SDA, INTERNAL_SCL);<br />
{<br />
int address;<br />
int error;</p>
<p dir="auto">/********** Internal ********/<br />
Serial.println("Scanning internal I2C");<br />
for(address = 1; address &lt; 127; address++)<br />
{<br />
Wire.beginTransmission(address);<br />
error = Wire.endTransmission();<br />
if(error == 0)<br />
{<br />
Serial.printf("Internal Device Found %#04x\n",address);<br />
}<br />
delay(10);<br />
}<br />
Serial.println("Done Scanning internal I2C");<br />
delay(500);</p>
<p dir="auto">/********** PortA ********/</p>
<p dir="auto">Serial.println("Scanning external I2C (PortA)");<br />
Wire1.begin(PortA_SDA, PortA_SCL);<br />
{<br />
Wire1.beginTransmission(address);<br />
error = Wire1.endTransmission();<br />
{<br />
Serial.printf("PORT-A Device Found %#04x\n",address);<br />
} else Serial.print("."); <a href="//Serial.printf" target="_blank" rel="noopener noreferrer nofollow ugc">//Serial.printf</a>("No Device Found PORT-A %#04x\n",address);<br />
delay(10);<br />
}<br />
Serial.println("Done Scanning PortA I2C");<br />
delay(500);</p>
<p dir="auto">/********** PortB ********/</p>
<p dir="auto">Serial.println("Scanning external I2C (PortB)");<br />
Wire1.begin(PortB_SDA, PortB_SCL);<br />
{<br />
{<br />
Serial.printf("PORT-B Device Found %#04x\n",address);<br />
} else  Serial.print("."); <a href="//Serial.printf" target="_blank" rel="noopener noreferrer nofollow ugc">//Serial.printf</a>("No Device Found PORT-B %#04x\n",address);<br />
delay(10);<br />
}<br />
Serial.println("Done Scanning PortB I2C");<br />
delay(500);</p>
<p dir="auto">/********** PortC ********/</p>
<p dir="auto">Serial.println("Scanning external I2C (PortC)");<br />
Wire1.begin(PortC_SDA, PortC_SCL);<br />
{<br />
{<br />
Serial.printf("PORT-C Device Found %#04x\n",address);<br />
} else  Serial.print("."); <a href="//Serial.printf" target="_blank" rel="noopener noreferrer nofollow ugc">//Serial.printf</a>("No Device Found PORT-C %#04x\n",address);<br />
delay(10);<br />
}<br />
delay(5000);<br />
]]></description><link>https://community.m5stack.com/topic/4677/m5stack-paper-i2c-doesn-t-work</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 23:11:36 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4677.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 05 Oct 2022 19:04:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack Paper I2C Doesn&#x27;t work on Wed, 28 Dec 2022 16:26:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/koiru" aria-label="Profile: Koiru">@<bdi>Koiru</bdi></a> I have not found a solution but I have found a workaround.</p>
<p dir="auto">The culprit creating the constant reboots are the touchscreen, if I call the begin function without enabling the touchscreen I can get the unit to work instead of doing constant reboots.</p>
<p dir="auto">To initialize the unit without touchscreen, use the following arguments:</p>
<pre><code>M5.begin(false, true, true, true, true);
]]></description><link>https://community.m5stack.com/post/19676</link><guid isPermaLink="true">https://community.m5stack.com/post/19676</guid><dc:creator><![CDATA[Morne]]></dc:creator><pubDate>Wed, 28 Dec 2022 16:26:04 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Paper I2C Doesn&#x27;t work on Fri, 09 Dec 2022 09:39:12 GMT]]></title><description><![CDATA[<p dir="auto">I'm having exactly the same issue. Have you figured out what causes it?</p>
]]></description><link>https://community.m5stack.com/post/19492</link><guid isPermaLink="true">https://community.m5stack.com/post/19492</guid><dc:creator><![CDATA[Koiru]]></dc:creator><pubDate>Fri, 09 Dec 2022 09:39:12 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Paper I2C Doesn&#x27;t work on Fri, 07 Oct 2022 23:23:13 GMT]]></title><description><![CDATA[<p dir="auto">Yes. That looks to be the case that it crashed after one or two Wire1 commands. Usually one period is printed but sometimes two. Also the internal I2C does not work is I call M5.begin but it does if I just call Wire.begin.</p>
]]></description><link>https://community.m5stack.com/post/18889</link><guid isPermaLink="true">https://community.m5stack.com/post/18889</guid><dc:creator><![CDATA[ispybadguys]]></dc:creator><pubDate>Fri, 07 Oct 2022 23:23:13 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Paper I2C Doesn&#x27;t work on Fri, 07 Oct 2022 08:27:42 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/ispybadguys" aria-label="Profile: ispybadguys">@<bdi>ispybadguys</bdi></a></p>
<p dir="auto">the debug output suggests that as soon as the I2C port scan starts (first dot) your M5Paper seems to reboot.</p>
<li>Have you tried a different / shorter USB cable? Maybe the issue is power related?</li>
<li>Does the <a href="https://github.com/m5stack/M5EPD/blob/main/examples/Basics/TOUCH/TOUCH.ino" target="_blank" rel="noopener noreferrer nofollow ugc">touch example</a> (requires internal I2C) work?</li>
]]></description><link>https://community.m5stack.com/post/18879</link><guid isPermaLink="true">https://community.m5stack.com/post/18879</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 07 Oct 2022 08:27:42 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Paper I2C Doesn&#x27;t work on Thu, 06 Oct 2022 19:44:11 GMT]]></title><description><![CDATA[<p dir="auto">Felix</p>
<p dir="auto">Yes. I just tried that. I get the same behavior. I moved the script to a new Windows computer and installed the IDE there. I get<br />
13:10:21.290 -&gt; I2C Scan - Port A<br />
13:10:21.290 -&gt; .M5EPD initializing...OK<br />
13:10:25.790 -&gt; I2C Scan - Port A</p>
<p dir="auto">I can actually scan the internal ports correctly if I don't call M5.begin(); and I just do a Serial.begin() and the wire commands.</p>
<p dir="auto">BTW the boards.txt has an error in it for the M5-Paper and you cannot upload code from the Arduino IDE. I fixed that and I can upload ok now.</p>
<p dir="auto">Kurt</p>
]]></description><link>https://community.m5stack.com/post/18874</link><guid isPermaLink="true">https://community.m5stack.com/post/18874</guid><dc:creator><![CDATA[ispybadguys]]></dc:creator><pubDate>Thu, 06 Oct 2022 19:44:11 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Paper I2C Doesn&#x27;t work on Thu, 06 Oct 2022 12:35:28 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/ispybadguys" aria-label="Profile: ispybadguys">@<bdi>ispybadguys</bdi></a></p>
<p dir="auto">that is very weird - I am stumped.</p>
<p dir="auto">Have you tried to only scan the ports by commenting these two lines:</p>
<pre><code>//  Serial.println("I2C Scan - internal");
//  scanI2C(i2cBus_Internal.wire, i2cBus_Internal.sda, i2cBus_Internal.scl);
<p dir="auto">BTW: I also get a 4 seconds delay before <code>OK</code> is printed out - so that should be fine.</p>
]]></description><link>https://community.m5stack.com/post/18866</link><guid isPermaLink="true">https://community.m5stack.com/post/18866</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 06 Oct 2022 12:35:28 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Paper I2C Doesn&#x27;t work on Thu, 06 Oct 2022 12:06:47 GMT]]></title><description><![CDATA[<p dir="auto">Felix</p>
<p dir="auto">Thanks for the code . For scanning the I2C. The code produces the following output:</p>
<p dir="auto">M5EPD initializing...OK<br />
I2C Scan - internal<br />
.M5EPD initializing...OK</p>
]]></description><link>https://community.m5stack.com/post/18864</link><guid isPermaLink="true">https://community.m5stack.com/post/18864</guid><dc:creator><![CDATA[ispybadguys]]></dc:creator><pubDate>Thu, 06 Oct 2022 12:06:47 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Paper I2C Doesn&#x27;t work on Thu, 06 Oct 2022 12:01:38 GMT]]></title><description><![CDATA[<p dir="auto">Yes. I tested the very code you have here with just to include and M5.begin() and I get M5EPD initializing... followed by a 4 second pause and then the OK</p>
]]></description><link>https://community.m5stack.com/post/18863</link><guid isPermaLink="true">https://community.m5stack.com/post/18863</guid><dc:creator><![CDATA[ispybadguys]]></dc:creator><pubDate>Thu, 06 Oct 2022 12:01:38 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Paper I2C Doesn&#x27;t work on Thu, 06 Oct 2022 10:14:47 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/ispybadguys" aria-label="Profile: ispybadguys">@<bdi>ispybadguys</bdi></a></p>
<p dir="auto">please find the I2C internal and all port scanner (which works for me) <a href="https://github.com/felmue/MyM5StackExamples/blob/main/M5Paper/I2CScanInternalAndAllPorts.ino" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/18862</link><guid isPermaLink="true">https://community.m5stack.com/post/18862</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 06 Oct 2022 10:14:47 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Paper I2C Doesn&#x27;t work on Thu, 06 Oct 2022 07:22:56 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/ispybadguys" aria-label="Profile: ispybadguys">@<bdi>ispybadguys</bdi></a></p>
<p dir="auto">are you saying that simply calling <code>M5.begin()</code> in <code>setup()</code>, e.g.</p>
  M5.begin();
<p dir="auto">produces <code>M5EPD initializing...OK</code> over and over again?</p>
]]></description><link>https://community.m5stack.com/post/18859</link><guid isPermaLink="true">https://community.m5stack.com/post/18859</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 06 Oct 2022 07:22:56 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Paper I2C Doesn&#x27;t work on Thu, 06 Oct 2022 04:13:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ispybadguys" aria-label="Profile: ispybadguys">@<bdi>ispybadguys</bdi></a> What external devices have you tried connecting?</p>
]]></description><link>https://community.m5stack.com/post/18854</link><guid isPermaLink="true">https://community.m5stack.com/post/18854</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 06 Oct 2022 04:13:34 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Paper I2C Doesn&#x27;t work on Thu, 06 Oct 2022 02:58:14 GMT]]></title><description><![CDATA[<p dir="auto">If I comment out the internal I2C section so I only have the PORT-A scan I get the following:</p>
<p dir="auto">Scanning external I2C (PortA)<br />
..............................................................................................................................Done Scanning PortA I2C</p>
<p dir="auto">It takes about one second for each address scanned. This is probably the default timeout.</p>
]]></description><link>https://community.m5stack.com/post/18853</link><guid isPermaLink="true">https://community.m5stack.com/post/18853</guid><dc:creator><![CDATA[ispybadguys]]></dc:creator><pubDate>Thu, 06 Oct 2022 02:58:14 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Paper I2C Doesn&#x27;t work on Thu, 06 Oct 2022 02:49:12 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. I'll try that. When I call M5.begin(); I get the following behavior.</p>
<p dir="auto">continues forever.</p>
]]></description><link>https://community.m5stack.com/post/18852</link><guid isPermaLink="true">https://community.m5stack.com/post/18852</guid><dc:creator><![CDATA[ispybadguys]]></dc:creator><pubDate>Thu, 06 Oct 2022 02:49:12 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Paper I2C Doesn&#x27;t work on Wed, 05 Oct 2022 20:20:52 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/ispybadguys" aria-label="Profile: ispybadguys">@<bdi>ispybadguys</bdi></a></p>
<p dir="auto">calling <code>M5.begin()</code> already takes care of <code>Serial</code> and <code>Wire</code>. I suggest you only call <code>M5.begin()</code> (which also initialises other M5Paper hardware) in <code>setup()</code>.</p>
<p dir="auto">As for the I2C scanning on the three ports. The latest ESP32 Arduino framework doesn't allow to just call <code>Wire1.begin()</code> repeatedly with different GPIOs for SDA and SCL. If you look at the debug output you'll see this warning <code>[ 41263][W][Wire.cpp:204] begin(): Bus already started in Master Mode.</code> every time you try that in the <code>loop()</code>.</p>
<p dir="auto">So when the scanning is done for one port you need to call <code>Wire1.end()</code> before calling <code>Wire1.begin()</code> again.</p>
]]></description><link>https://community.m5stack.com/post/18844</link><guid isPermaLink="true">https://community.m5stack.com/post/18844</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 05 Oct 2022 20:20:52 GMT</pubDate></item></channel></rss>
