<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unit ACSSR U139 mode change, micropython]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I start to test the Module and I could not change the mode with the Button, the module blink only 6 times red. Is there in other hack to change the mode?<br />
Then I tried to change the firmware with micro python but the ESP32 sends only invalid header: 0xffffffff after flashing. The ESP32 should work with the standard firmware or is there any difference?<br />
If I want to change the firmware back, is there a manual to flash, it?</p>
]]></description><link>https://community.m5stack.com/topic/4678/unit-acssr-u139-mode-change-micropython</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 20:37:41 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4678.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 05 Oct 2022 20:11:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unit ACSSR U139 mode change, micropython on Thu, 06 Oct 2022 18:37:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a> That was my hope too and I was disappointed to find it controlled by an esp32 but not wifi accessible :(</p>
]]></description><link>https://community.m5stack.com/post/18873</link><guid isPermaLink="true">https://community.m5stack.com/post/18873</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 06 Oct 2022 18:37:12 GMT</pubDate></item><item><title><![CDATA[Reply to Unit ACSSR U139 mode change, micropython on Thu, 06 Oct 2022 09:07:23 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a></p>
<p dir="auto">FYI: getting access to the programming pins isn't that hard. However if you'd like to run anything on the internal ESP32 that requires WiFi, you'd need to add a WiFi antenna. The traces are there on the board but the necessary parts are not populated.</p>
]]></description><link>https://community.m5stack.com/post/18861</link><guid isPermaLink="true">https://community.m5stack.com/post/18861</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 06 Oct 2022 09:07:23 GMT</pubDate></item><item><title><![CDATA[Reply to Unit ACSSR U139 mode change, micropython on Thu, 06 Oct 2022 04:54:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> You know, Adam, I bought an ACSSR intending it to be turned on by ESP_NOW, but was gutted to find that the programming pins are not brought out.<br />
It works as advertised, but not like all other M5Stack products, which are very useful ESP32 devices, and infinitely programmable.<br />
I made an ASSumption!<br />
Cheers</p>
]]></description><link>https://community.m5stack.com/post/18857</link><guid isPermaLink="true">https://community.m5stack.com/post/18857</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Thu, 06 Oct 2022 04:54:29 GMT</pubDate></item><item><title><![CDATA[Reply to Unit ACSSR U139 mode change, micropython on Thu, 06 Oct 2022 04:18:40 GMT]]></title><description><![CDATA[<p dir="auto">There isn't a software mode select but changing modes can be a bit of a challenge.</p>
<p dir="auto">What I have been able to do is recorded here : <a href="https://www.hackster.io/AJB2K3/get-started-with-the-m5stack-acssr-cf960b" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.hackster.io/AJB2K3/get-started-with-the-m5stack-acssr-cf960b</a></p>
]]></description><link>https://community.m5stack.com/post/18855</link><guid isPermaLink="true">https://community.m5stack.com/post/18855</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 06 Oct 2022 04:18:40 GMT</pubDate></item><item><title><![CDATA[Reply to Unit ACSSR U139 mode change, micropython on Wed, 05 Oct 2022 20:39:15 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/arminfriedel" aria-label="Profile: ArminFriedel">@<bdi>ArminFriedel</bdi></a></p>
<p dir="auto">to change the mode do the following:</p>
<li>remove power</li>
<li>press and hold button</li>
<li>apply power --&gt; RGB LED should blink rapidly</li>
<li>short press button until the RGB LED rapidly blinks in the color of the mode you want</li>
<li>confirm mode with a long press</li>
<p dir="auto">If you want to modify the internal firmware you need to open the case to access the standard connector to flash the internal ESP32. Check out the <a href="https://docs.m5stack.com/en/unit/acssr" target="_blank" rel="noopener noreferrer nofollow ugc">schematic</a> - J1 is the programming connector.</p>
<p dir="auto">Standard firmware can be found <a href="https://github.com/m5stack/M5Unit-ACSSR-Internal-FW" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>. You'll need the <a href="https://docs.espressif.com/projects/esp-idf/en/latest/esp32/" target="_blank" rel="noopener noreferrer nofollow ugc">Espressif ESP-IDF environment</a> to compile, link and flash.</p>
]]></description><link>https://community.m5stack.com/post/18848</link><guid isPermaLink="true">https://community.m5stack.com/post/18848</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 05 Oct 2022 20:39:15 GMT</pubDate></item></channel></rss>
