<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How does the download work?]]></title><description><![CDATA[<p dir="auto">I have just connected my m5stick to the internet.<br />
I have used the api key to connect the online programming software to the m5 stick<br />
I have created my program and tested that it's running using the play button on the ui flow<br />
I have clicked on the side menu and use the "DOWNLOAD" option to download the program to the m5 stick<br />
Now i have disconnected the stick from usb on my computer and i want to run the software from the m5stick to my led board<br />
it doesnt work</p>
<p dir="auto">i now want to reconnect my m5stick to the uiflow<br />
i press the side button twice to turn the m5stick off<br />
i press it once to turn it on<br />
now the board (not plugged into my computer using usb) is just turning on and off the screen saying UIFLOW</p>
<p dir="auto">when i try to connect or search for the m5stick in the wifi i cannot find the wifi. the screen still blinks on and off uiflow v1.0.0</p>
<p dir="auto">i dont know what to do.</p>
<li>
<p dir="auto">download should download the code to run without wifi - correct?</p>
</li>
<li>
<p dir="auto">why does the screen blink on and off uiflow?</p>
</li>
<li>
<p dir="auto">how can i reconnect it to the wifi so i can try to download the program again?</p>
</li>
]]></description><link>https://community.m5stack.com/topic/468/how-does-the-download-work</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 01:07:08 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/468.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Jan 2019 17:58:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How does the download work? on Mon, 21 Jan 2019 17:45:27 GMT]]></title><description><![CDATA[<p dir="auto">Does it do the same with the USB lead plugged it?<br />
It could be that the battery isn't charged enough.</p>
<p dir="auto">to reconnect, Plug the usb into a battery or laptop to power on and start charging the M5, When it beeps the main menu will briefly pop up, you hit to hit button C (right button) as soon as the screen appears this will send you to the wifi screen and you use c button to move do to the "reconnect to uiflow" option then hit the middle (B) button to connect.<br />
Go into UIFlow and hit the circle symbol next to (disconnected) to reconnect to the M5 (Sometime it will auto connect and say connected in green).</p>
]]></description><link>https://community.m5stack.com/post/2606</link><guid isPermaLink="true">https://community.m5stack.com/post/2606</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 21 Jan 2019 17:45:27 GMT</pubDate></item><item><title><![CDATA[Reply to How does the download work? on Mon, 21 Jan 2019 16:42:10 GMT]]></title><description><![CDATA[<p dir="auto">Hello, <a class="plugin-mentions-user plugin-mentions-a" href="/user/heybin" aria-label="Profile: heybin">@<bdi>heybin</bdi></a>, which button (A,B,C)?</p>
]]></description><link>https://community.m5stack.com/post/2604</link><guid isPermaLink="true">https://community.m5stack.com/post/2604</guid><dc:creator><![CDATA[dvd78]]></dc:creator><pubDate>Mon, 21 Jan 2019 16:42:10 GMT</pubDate></item><item><title><![CDATA[Reply to How does the download work? on Wed, 02 Jan 2019 05:39:02 GMT]]></title><description><![CDATA[<p dir="auto">hello, reboot stick, when uiflow ui appear, press button can change begin app: uiflow &lt;---&gt; user donlownd code</p>
]]></description><link>https://community.m5stack.com/post/2300</link><guid isPermaLink="true">https://community.m5stack.com/post/2300</guid><dc:creator><![CDATA[heybin]]></dc:creator><pubDate>Wed, 02 Jan 2019 05:39:02 GMT</pubDate></item><item><title><![CDATA[Reply to How does the download work? on Wed, 02 Jan 2019 04:05:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/360fashion" aria-label="Profile: 360fashion">@<bdi>360fashion</bdi></a><br />
Happy New Year, Guy! Does your m5stick work normally now?</p>
]]></description><link>https://community.m5stack.com/post/2294</link><guid isPermaLink="true">https://community.m5stack.com/post/2294</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Wed, 02 Jan 2019 04:05:50 GMT</pubDate></item></channel></rss>
