<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[OEM OOTB Code]]></title><description><![CDATA[<p dir="auto">I see this referenced in many threads here on the forum, but I do not see anything definitive.<br />
Also there are no comment in the code that could clarify this...</p>
<p dir="auto"><strong>Is the example sketch "FactoryTest" the code that ships preloaded</strong> on a new device (mine is M5StickC-plus)  ?</p>
<p dir="auto">(it'd be nice as a safety-net to fall back to should I mess up something while learning)</p>
]]></description><link>https://community.m5stack.com/topic/4685/oem-ootb-code</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:34:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4685.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 07 Oct 2022 06:08:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to OEM OOTB Code on Sat, 08 Oct 2022 06:17:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5_tinker" aria-label="Profile: m5_tinker">@<bdi>m5_tinker</bdi></a> It should be, the M5Burner version is just precompiled ready to burn where as the Arduino version has to be compiled and burned.</p>
]]></description><link>https://community.m5stack.com/post/18902</link><guid isPermaLink="true">https://community.m5stack.com/post/18902</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 08 Oct 2022 06:17:15 GMT</pubDate></item><item><title><![CDATA[Reply to OEM OOTB Code on Fri, 07 Oct 2022 13:57:32 GMT]]></title><description><![CDATA[<p dir="auto">Any idea if the "Factory Test" included in M5Burner is the same as the "FactoryTest" in the Arduino library example?</p>
]]></description><link>https://community.m5stack.com/post/18886</link><guid isPermaLink="true">https://community.m5stack.com/post/18886</guid><dc:creator><![CDATA[M5_Tinker]]></dc:creator><pubDate>Fri, 07 Oct 2022 13:57:32 GMT</pubDate></item><item><title><![CDATA[Reply to OEM OOTB Code on Fri, 07 Oct 2022 12:46:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5_tinker" aria-label="Profile: m5_tinker">@<bdi>m5_tinker</bdi></a> You will find the factory test firmware comes pre installed in M5Burner, M5stacks Firmware installation tool.</p>
]]></description><link>https://community.m5stack.com/post/18883</link><guid isPermaLink="true">https://community.m5stack.com/post/18883</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 07 Oct 2022 12:46:14 GMT</pubDate></item></channel></rss>
