<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[No COM Port with M5 Fire but another M5 has]]></title><description><![CDATA[<p dir="auto">Hi there,<br />
i just got a M5stack Fire. But if i connect it there is no connection with my Win Pc.<br />
Another 'normal' M5 shows connection on COM9. And i use Arduino IDE without problems.<br />
But the Fire doesnt connect.</p>
<p dir="auto">What did i miss?<br />
Thanks</p>
]]></description><link>https://community.m5stack.com/topic/472/no-com-port-with-m5-fire-but-another-m5-has</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 17:47:07 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/472.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 04 Jan 2019 13:44:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to No COM Port with M5 Fire but another M5 has on Thu, 10 Jan 2019 14:50:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a><br />
No, there was no COM-Port. As if it is not plugged or turned wrong around.<br />
But as told, now it is ok. And i am glad it is. I like the M5s very much.</p>
<p dir="auto">I still think, the capacitor solved it. But of course i am not sure.</p>
]]></description><link>https://community.m5stack.com/post/2438</link><guid isPermaLink="true">https://community.m5stack.com/post/2438</guid><dc:creator><![CDATA[Dreitagebert]]></dc:creator><pubDate>Thu, 10 Jan 2019 14:50:56 GMT</pubDate></item><item><title><![CDATA[Reply to No COM Port with M5 Fire but another M5 has on Wed, 09 Jan 2019 02:55:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dreitagebert" aria-label="Profile: dreitagebert">@<bdi>dreitagebert</bdi></a><br />
Does the PC device manager appear "COM" when the FIR can not connect with PC as shown below?</p>
<p dir="auto"><img src="/assets/uploads/files/1547002533422-faq_com_port_02.png" alt="0_1547002533074_faq_com_port_02.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/2399</link><guid isPermaLink="true">https://community.m5stack.com/post/2399</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Wed, 09 Jan 2019 02:55:41 GMT</pubDate></item><item><title><![CDATA[Reply to No COM Port with M5 Fire but another M5 has on Mon, 07 Jan 2019 14:56:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a><br />
Thanks for your answer.<br />
I could connect after bridging GND with G0.<br />
Before i tried to reverse USB plug many times without success.</p>
<p dir="auto">For this reason (and because i have so many of them) wouldn´t it be nice to use Micro-USB?  Most ESPs, Mobiles and many more use it and all of us have them for charging all the devices.</p>
]]></description><link>https://community.m5stack.com/post/2375</link><guid isPermaLink="true">https://community.m5stack.com/post/2375</guid><dc:creator><![CDATA[Dreitagebert]]></dc:creator><pubDate>Mon, 07 Jan 2019 14:56:09 GMT</pubDate></item><item><title><![CDATA[Reply to No COM Port with M5 Fire but another M5 has on Mon, 07 Jan 2019 06:41:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felix42eu" aria-label="Profile: felix42eu">@<bdi>felix42eu</bdi></a><br />
Really? Tell me the detailed situation please.</p>
]]></description><link>https://community.m5stack.com/post/2372</link><guid isPermaLink="true">https://community.m5stack.com/post/2372</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Mon, 07 Jan 2019 06:41:50 GMT</pubDate></item><item><title><![CDATA[Reply to No COM Port with M5 Fire but another M5 has on Mon, 07 Jan 2019 06:40:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dreitagebert" aria-label="Profile: dreitagebert">@<bdi>dreitagebert</bdi></a><br />
Hi, If a Fire was connected with PC through USB cable and the PC doesn't appear COM Port, please reverse USB and plug in Fire again.</p>
<p dir="auto"><img src="/assets/uploads/files/1546843230973-tim%E6%88%AA%E5%9B%BE20190107143835.png" alt="0_1546843230782_TIM截图20190107143835.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/2371</link><guid isPermaLink="true">https://community.m5stack.com/post/2371</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Mon, 07 Jan 2019 06:40:35 GMT</pubDate></item><item><title><![CDATA[Reply to No COM Port with M5 Fire but another M5 has on Mon, 07 Jan 2019 06:37:58 GMT]]></title><description><![CDATA[<p dir="auto">I managed to reach the fire by putting a little capacitor between Gnd and G0.<br />
Sometimes. It is more astrological than technical.</p>
<p dir="auto">As i read on another place, there is a failure in the board layout and one piece should be turned but my fingers are really too big to solder such small pieces.</p>
<p dir="auto">Such a pity. I will send it back. In this way i cannot use it.</p>
]]></description><link>https://community.m5stack.com/post/2370</link><guid isPermaLink="true">https://community.m5stack.com/post/2370</guid><dc:creator><![CDATA[Dreitagebert]]></dc:creator><pubDate>Mon, 07 Jan 2019 06:37:58 GMT</pubDate></item><item><title><![CDATA[Reply to No COM Port with M5 Fire but another M5 has on Sat, 05 Jan 2019 20:52:02 GMT]]></title><description><![CDATA[<p dir="auto">Hi Dreitagebert,<br />
which firmware do you run?<br />
I have seen versions (like v1.0.2-en) that do not have an COM-Port</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a>: Why is this so?</p>
<p dir="auto">Sincerely<br />
]]></description><link>https://community.m5stack.com/post/2344</link><guid isPermaLink="true">https://community.m5stack.com/post/2344</guid><dc:creator><![CDATA[felix42eu]]></dc:creator><pubDate>Sat, 05 Jan 2019 20:52:02 GMT</pubDate></item></channel></rss>
