<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core Third Party Blocks - make available on Fire]]></title><description><![CDATA[<p dir="auto">I have a Fire and was trying out controlling a Tello Drone.</p>
<p dir="auto">The third-party block for Tello is available in M5Flow for core but not fire.</p>
<p dir="auto">If I configure my fire as a core then the code downloads and works.<br />
This set of blocks is a library that works over a wifi connection, so should work on any controller.</p>
<p dir="auto">Please can you add the 3rd party blocks available to core to the fire (and core2?)</p>
]]></description><link>https://community.m5stack.com/topic/4726/core-third-party-blocks-make-available-on-fire</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:45:18 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4726.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 17 Oct 2022 23:43:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core Third Party Blocks - make available on Fire on Wed, 19 Oct 2022 14:24:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glp" aria-label="Profile: glp">@<bdi>glp</bdi></a> Thanks, I will check that out.</p>
<p dir="auto">It does work if I change the device type to a core, even though it is downloading to a fire.</p>
<p dir="auto">Given that it just sends text instructions via a Wi-Fi network connection, it should be portable to any M5Stack controller.</p>
<p dir="auto">Ideally UIFlow would let you simply import/include various 3rd party libraries as needed.</p>
]]></description><link>https://community.m5stack.com/post/19038</link><guid isPermaLink="true">https://community.m5stack.com/post/19038</guid><dc:creator><![CDATA[notdodgy]]></dc:creator><pubDate>Wed, 19 Oct 2022 14:24:22 GMT</pubDate></item><item><title><![CDATA[Reply to Core Third Party Blocks - make available on Fire on Tue, 18 Oct 2022 08:44:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/notdodgy" aria-label="Profile: notdodgy">@<bdi>notdodgy</bdi></a> glad for your interest, i havent't test Tello custom blocks on Fire yet, but i'm sure it work (tested the python code also on ESP8266).  For the moment, if you prefer stay on uiflow setting on Fire, you might follow this step by step instructions  on <a href="https://www.hackster.io/gperrella/m5-block-dji-tello-drone-control-c2646f" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.hackster.io/gperrella/m5-block-dji-tello-drone-control-c2646f</a> . I explain how load  <a href="http://tello.py" target="_blank" rel="noopener noreferrer nofollow ugc">tello.py</a> directly at root of your firmware, then load  custom block Tello5.m5b, only after that load the TelloTest5.m5f.<br />
To embed firmly Tello blocks on the Fire firmware, we have to ask our friends of M5Stack, they only have the basic code to include on their micropython release.  Hope is all clear, thanks  again</p>
]]></description><link>https://community.m5stack.com/post/19029</link><guid isPermaLink="true">https://community.m5stack.com/post/19029</guid><dc:creator><![CDATA[GLP]]></dc:creator><pubDate>Tue, 18 Oct 2022 08:44:32 GMT</pubDate></item><item><title><![CDATA[Reply to Core Third Party Blocks - make available on Fire on Tue, 18 Oct 2022 04:57:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/notdodgy" aria-label="Profile: notdodgy">@<bdi>notdodgy</bdi></a> the Tello drone functions are developed by @gperelly and I don't know if he has a fire to test.<br />
The fire and core have slight hardware differences. I'll drop him a message pointing here.</p>
]]></description><link>https://community.m5stack.com/post/19026</link><guid isPermaLink="true">https://community.m5stack.com/post/19026</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 18 Oct 2022 04:57:45 GMT</pubDate></item></channel></rss>
