<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Core2 cannot upload failed to write to target RAM]]></title><description><![CDATA[<p dir="auto">I just received the beautiful M5 Core2 unit and was trying to get the factory test to upload. Unfortunately I get an error I see in other posts.</p>
<p dir="auto">Chip is ESP32-D0WDQ6-V3 (revision 3)<br />
WARNING: Detected crystal freq 41.01MHz is quite different to normalized freq 40MHz. Unsupported crystal in use?<br />
Crystal is 40MHz<br />
MAC: 78:21:84:93:38:58<br />
Uploading stub...</p>
<p dir="auto">A fatal error occurred: Failed to write to target RAM (result was 01070000: Operation timed out)<br />
A fatal error occurred: Failed to write to target RAM (result was 01070000: Operation timed out)</p>
<p dir="auto">I can upload to all the other M5 devices and ESP-32. This occurs on my Mac with the M1 chip, but also with an older Mac.</p>
<p dir="auto">I've tried the USB-C to USB-C as well as USB-A to USB-C. No difference.</p>
]]></description><link>https://community.m5stack.com/topic/4727/m5core2-cannot-upload-failed-to-write-to-target-ram</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 07:57:05 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4727.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 18 Oct 2022 01:02:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Core2 cannot upload failed to write to target RAM on Thu, 27 Oct 2022 10:14:49 GMT]]></title><description><![CDATA[<p dir="auto">I also encountered the same problem when using M5 core 2. My macOS system version is 10.14.6</p>
]]></description><link>https://community.m5stack.com/post/19124</link><guid isPermaLink="true">https://community.m5stack.com/post/19124</guid><dc:creator><![CDATA[Victor1102]]></dc:creator><pubDate>Thu, 27 Oct 2022 10:14:49 GMT</pubDate></item><item><title><![CDATA[Reply to M5Core2 cannot upload failed to write to target RAM on Tue, 18 Oct 2022 04:55:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/konacurrents" aria-label="Profile: konacurrents">@<bdi>konacurrents</bdi></a> What OS version are you using as OSX is a pain at the moment.</p>
]]></description><link>https://community.m5stack.com/post/19025</link><guid isPermaLink="true">https://community.m5stack.com/post/19025</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 18 Oct 2022 04:55:22 GMT</pubDate></item></channel></rss>
