<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5STATION NO RS485 SUPPORT (let alone Modbus RTU) [EDIT: solution w&#x2F;example inside]]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">the main reason i bought the M5STATION was the RS485 support.<br />
I was pretty puzzled when I saw this element not to be included in the examples!  - Let alone the modbus RTU implementation.</p>
<p dir="auto">I hope I'm in being mistaken and effectively the support for this port is available because it's the basics for use in industrial environment.</p>
<p dir="auto">To be fair and concise, at the cost of sounding not so nice :-)   : Arduino has a very good Modbus library that any device with aspiration of industrial adoption should support:<br />
<a href="https://www.arduino.cc/reference/en/libraries/arduinomodbus/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.arduino.cc/reference/en/libraries/arduinomodbus/</a></p>
<p dir="auto">Are there any plans/maybe it's already done to "fix" it to run on M5STATION?</p>
]]></description><link>https://community.m5stack.com/topic/4740/m5station-no-rs485-support-let-alone-modbus-rtu-edit-solution-w-example-inside</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:05:14 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4740.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 21 Oct 2022 14:51:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5STATION NO RS485 SUPPORT (let alone Modbus RTU) [EDIT: solution w&#x2F;example inside] on Thu, 27 Oct 2022 16:32:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Just an udpate: everything is working as intended. Thanks!</p>
]]></description><link>https://community.m5stack.com/post/19126</link><guid isPermaLink="true">https://community.m5stack.com/post/19126</guid><dc:creator><![CDATA[Caterpillaraoz]]></dc:creator><pubDate>Thu, 27 Oct 2022 16:32:22 GMT</pubDate></item><item><title><![CDATA[Reply to M5STATION NO RS485 SUPPORT (let alone Modbus RTU) [EDIT: solution w&#x2F;example inside] on Wed, 26 Oct 2022 13:11:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Seems to be working - at least in producing compliants packets. Thanks again!</p>
]]></description><link>https://community.m5stack.com/post/19120</link><guid isPermaLink="true">https://community.m5stack.com/post/19120</guid><dc:creator><![CDATA[Caterpillaraoz]]></dc:creator><pubDate>Wed, 26 Oct 2022 13:11:06 GMT</pubDate></item><item><title><![CDATA[Reply to M5STATION NO RS485 SUPPORT (let alone Modbus RTU) [EDIT: solution w&#x2F;example inside] on Mon, 24 Oct 2022 12:18:33 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/caterpillaraoz" aria-label="Profile: Caterpillaraoz">@<bdi>Caterpillaraoz</bdi></a></p>
<p dir="auto">yes, my example uses the RS485 port from the M5Station (acting as Modbus client) controlling the ACSSR (as Modbus server).</p>
<p dir="auto">You will need to modify the example to send out the proper commands to the Modbus device (or devices) you want to control.</p>
]]></description><link>https://community.m5stack.com/post/19095</link><guid isPermaLink="true">https://community.m5stack.com/post/19095</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 24 Oct 2022 12:18:33 GMT</pubDate></item><item><title><![CDATA[Reply to M5STATION NO RS485 SUPPORT (let alone Modbus RTU) [EDIT: solution w&#x2F;example inside] on Mon, 24 Oct 2022 11:07:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> said in <a href="/post/19061">M5STATION NO RS485 SUPPORT (let alone Modbus RTU)</a>:</p>
<p dir="auto">your post made me curious and since I have both an <a href="https://docs.m5stack.com/en/core/station_485" target="_blank" rel="noopener noreferrer nofollow ugc">M5Station 485</a> and an <a href="https://docs.m5stack.com/en/unit/acssr" target="_blank" rel="noopener noreferrer nofollow ugc">M5Unit-ACSSR</a> which has a Modbus mode I've put together an example. You can find it <a href="https://github.com/felmue/MyM5StackExamples/blob/main/M5Station/RS485ModbusACSSR.ino" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
<p dir="auto">Thank you for your time! It's compiling OK, that's a huge step forward for me, I'll take it as a starting point. Tomorrow in the ofice I'll do a live test &amp; update you.</p>
<p dir="auto">Let's see if I understood correctly... it should be communicating via the RS485 port built in in the station_485, NOT via the ACSSR unit, right?</p>
]]></description><link>https://community.m5stack.com/post/19094</link><guid isPermaLink="true">https://community.m5stack.com/post/19094</guid><dc:creator><![CDATA[Caterpillaraoz]]></dc:creator><pubDate>Mon, 24 Oct 2022 11:07:17 GMT</pubDate></item><item><title><![CDATA[Reply to M5STATION NO RS485 SUPPORT (let alone Modbus RTU) [EDIT: solution w&#x2F;example inside] on Fri, 21 Oct 2022 18:57:14 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/caterpillaraoz" aria-label="Profile: Caterpillaraoz">@<bdi>Caterpillaraoz</bdi></a></p>
]]></description><link>https://community.m5stack.com/post/19061</link><guid isPermaLink="true">https://community.m5stack.com/post/19061</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 21 Oct 2022 18:57:14 GMT</pubDate></item><item><title><![CDATA[Reply to M5STATION NO RS485 SUPPORT (let alone Modbus RTU) [EDIT: solution w&#x2F;example inside] on Fri, 21 Oct 2022 17:26:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> What's the method? I am seriously considering about embedding such devices in an industrial context but I'm having some doubts now.</p>
]]></description><link>https://community.m5stack.com/post/19059</link><guid isPermaLink="true">https://community.m5stack.com/post/19059</guid><dc:creator><![CDATA[Caterpillaraoz]]></dc:creator><pubDate>Fri, 21 Oct 2022 17:26:24 GMT</pubDate></item><item><title><![CDATA[Reply to M5STATION NO RS485 SUPPORT (let alone Modbus RTU) [EDIT: solution w&#x2F;example inside] on Fri, 21 Oct 2022 17:18:55 GMT]]></title><description><![CDATA[<p dir="auto">I had it working via a roundabout method but the screen has died on mine and so its sat on the desk doing nothing.</p>
]]></description><link>https://community.m5stack.com/post/19058</link><guid isPermaLink="true">https://community.m5stack.com/post/19058</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 21 Oct 2022 17:18:55 GMT</pubDate></item></channel></rss>
