<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Hardware Variantion and Firmware Compatibility]]></title><description><![CDATA[<h1>Hardware Variantion and Firmware Compatibility</h1>
<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a> ,<br />
I am wondering about the following:<br />
As far as I know there are this m5core-Modules:</p>
<li>m5stack</li>
<li>m5fire</li>
<li>m5camera (not yet)</li>
<li>m5stick</li>
<li>m5bala (unkown)</li>
<p dir="auto">Do they all work with the same core? (if I know correctly the m5stick will not have the ESP32)</p>
<p dir="auto">We have the following firmware items (taken from the M5burner dropdown):</p>
<li>M5cloud (with cloud app)</li>
<li>M5Go (with cloud app)</li>
<li>Flow (with cloud app)</li>
<li>M5Fire</li>
<li>M5Cam</li>
<li>M5Bala</li>
<li>
<p dir="auto">I would be interested in which of the hardware modules work with which firmware and cloud apps. Is there something like a cross reference table, or how could we create one?</p>
</li>
<li>
<p dir="auto">Which of the software is available in Open Source or which license are they published under?</p>
</li>
<li>
<p dir="auto">Which of the software is actively developed (M5cloud and M5go seem to be in Beta for quite a long time) any roadmaps for that?</p>
</li>
Sincerely<br />
]]></description><link>https://community.m5stack.com/topic/477/hardware-variantion-and-firmware-compatibility</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 17:47:07 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/477.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 05 Jan 2019 21:11:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Hardware Variantion and Firmware Compatibility on Sun, 06 Jan 2019 10:45:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felix42eu" aria-label="Profile: felix42eu">@<bdi>felix42eu</bdi></a> said in <a href="/post/2355">Hardware Variantion and Firmware Compatibility</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a>:</p>
<li>OK, I did not know that arduino was not fully supported. thanks.</li>
<li>is m5go and m5fire a different product? I do not think so.</li>
<li>where are the sources of the versions located if they are open source? or do you mean the binaries are free (I found them in the M5burner replease)</li>
<p dir="auto">The espressif idf is a topic which I have too look deeper into.</p>
<p dir="auto">All sources, documents and specs are found on github.</p>
<p dir="auto"><a href="https://github.com/m5stack" target="_blank" rel="noopener noreferrer nofollow ugc">Git Hub</a><br />
Some of the docs are a little out of date though.<br />
some of the "grove connection" units are found on the seeedstudio grove website.</p>
]]></description><link>https://community.m5stack.com/post/2357</link><guid isPermaLink="true">https://community.m5stack.com/post/2357</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 06 Jan 2019 10:45:23 GMT</pubDate></item><item><title><![CDATA[Reply to Hardware Variantion and Firmware Compatibility on Sat, 05 Jan 2019 23:10:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a>:</p>
]]></description><link>https://community.m5stack.com/post/2355</link><guid isPermaLink="true">https://community.m5stack.com/post/2355</guid><dc:creator><![CDATA[felix42eu]]></dc:creator><pubDate>Sat, 05 Jan 2019 23:10:47 GMT</pubDate></item><item><title><![CDATA[Reply to Hardware Variantion and Firmware Compatibility on Sat, 05 Jan 2019 21:48:41 GMT]]></title><description><![CDATA[<p dir="auto">All units use the esp32,<br />
Gen 1 cameras use raw esp32<br />
Gen 2/3 camera's and stick use the wroover module<br />
Core (i think) go and fire use the wrover</p>
<p dir="auto">All firmwares are available open source using the Espressif idf.</p>
<p dir="auto">All firmware and software is WIP as improvements keep being found and implemented.</p>
<p dir="auto">Programming via Arduino is problematic but possible (with the exception of the camera series)</p>
<p dir="auto">UIFlow, micro python  and espressif IDF are the IDF's of choice</p>
<p dir="auto">No, M5 stick came after the camera.</p>
<p dir="auto">All of the above information is from my understanding.</p>
]]></description><link>https://community.m5stack.com/post/2349</link><guid isPermaLink="true">https://community.m5stack.com/post/2349</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 05 Jan 2019 21:48:41 GMT</pubDate></item><item><title><![CDATA[Reply to Hardware Variantion and Firmware Compatibility on Sat, 05 Jan 2019 21:15:27 GMT]]></title><description><![CDATA[<p dir="auto">I do suggest the following:</p>
<li>M5cloud was the first version of the cloud app now replaced with Flow/UI.Flow</li>
<li>M5GO was the second version of the cloud app now replaced with Flow/UI.Flow</li>
<li>UI.Flow is compatible with all ESP32 systems (M5core and M5fire, sometimes called M5GO)</li>
<li>M5Cam is based on M5Stick</li>
<li>M5Bala will use ESP32</li>
]]></description><link>https://community.m5stack.com/post/2347</link><guid isPermaLink="true">https://community.m5stack.com/post/2347</guid><dc:creator><![CDATA[felix42eu]]></dc:creator><pubDate>Sat, 05 Jan 2019 21:15:27 GMT</pubDate></item></channel></rss>
