<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wifi Connection Speed]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I'm using  wifiCfg.doConnect(ssid, pass) to connect to the local Wifi. Which it is doing however it takes sometimes a few minutes.</p>
<p dir="auto">Is there a way to speed up this process or this delay seems to be as it is.</p>
<p dir="auto">regards</p>
<p dir="auto">Kyle</p>
]]></description><link>https://community.m5stack.com/topic/4772/wifi-connection-speed</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:43:27 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4772.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Nov 2022 06:24:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wifi Connection Speed on Wed, 02 Nov 2022 05:58:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robski" aria-label="Profile: robski">@<bdi>robski</bdi></a> I have noticed when I use the m5burner and embed my details it connects quickly. However the use case is that the wifi details are not know before hand and can change at any time. So that does not seem to be an option.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> thanks for the info its something I can work around in programming, just not optimal for user.</p>
]]></description><link>https://community.m5stack.com/post/19184</link><guid isPermaLink="true">https://community.m5stack.com/post/19184</guid><dc:creator><![CDATA[kylebuttress]]></dc:creator><pubDate>Wed, 02 Nov 2022 05:58:28 GMT</pubDate></item><item><title><![CDATA[Reply to Wifi Connection Speed on Tue, 01 Nov 2022 10:04:46 GMT]]></title><description><![CDATA[<p dir="auto">Unfortunately not, it’s to do with the esp running on the 2.4 GHz band so there is a network issue at play causing slow connection</p>
]]></description><link>https://community.m5stack.com/post/19181</link><guid isPermaLink="true">https://community.m5stack.com/post/19181</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 01 Nov 2022 10:04:46 GMT</pubDate></item><item><title><![CDATA[Reply to Wifi Connection Speed on Tue, 01 Nov 2022 08:06:31 GMT]]></title><description><![CDATA[<p dir="auto">how long it takes to connect if you burn firmware and set it up with network start for online UIflow? on my devices it usually connects in seconds</p>
]]></description><link>https://community.m5stack.com/post/19180</link><guid isPermaLink="true">https://community.m5stack.com/post/19180</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Tue, 01 Nov 2022 08:06:31 GMT</pubDate></item></channel></rss>
