<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 esp32 cam with solar charging out of the box]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">i would like to install as many people I think external camera for monitoring with the cheapest price</p>
<p dir="auto">I see this m5 product</p>
<p dir="auto"><a href="https://shop.m5stack.com/collections/m5-cameras/products/esp32-psram-timer-camera-fisheye-ov3660" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/collections/m5-cameras/products/esp32-psram-timer-camera-fisheye-ov3660</a></p>
<p dir="auto">But I understand If I use it as video monitoring, the battery will drain quickly, I don't want to add external power wire for this camera, so maybe solar charging is the solution</p>
<p dir="auto">I think people here already think / work on this kind of config</p>
<p dir="auto">If you can advice me on the combo for have this camera with solar charging without welding and tasks lite this, if you can find solarg charging system out of the box</p>
<p dir="auto">Thanks a lot for any advice</p>
]]></description><link>https://community.m5stack.com/topic/4776/m5-esp32-cam-with-solar-charging-out-of-the-box</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:02:28 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4776.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 04 Nov 2022 08:22:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 esp32 cam with solar charging out of the box on Sun, 27 Nov 2022 10:30:10 GMT]]></title><description><![CDATA[<p dir="auto">It's built like this image. My solar panel is a 5 volt 60mA panel. The battery is a 500mA lipo battery. The output on the right (in the image the dc-dc step up, my timercam is connected) in the image connects to the onboard connector of the Timercam. I've used the original plastic shipping case to construct a waterproof case for the components.<br />
<img src="https://iotdesignpro.com/sites/default/files/inline-images/TP4056-Module-Working.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/19392</link><guid isPermaLink="true">https://community.m5stack.com/post/19392</guid><dc:creator><![CDATA[jvdpol]]></dc:creator><pubDate>Sun, 27 Nov 2022 10:30:10 GMT</pubDate></item><item><title><![CDATA[Reply to M5 esp32 cam with solar charging out of the box on Sat, 26 Nov 2022 18:27:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jvdpol" aria-label="Profile: jvdpol">@<bdi>jvdpol</bdi></a> hi I liked your solution, can you post any type of complementary information about how to implement this solution? Maybe a schematics of the circuit will help.</p>
]]></description><link>https://community.m5stack.com/post/19390</link><guid isPermaLink="true">https://community.m5stack.com/post/19390</guid><dc:creator><![CDATA[vitormartins]]></dc:creator><pubDate>Sat, 26 Nov 2022 18:27:13 GMT</pubDate></item><item><title><![CDATA[Reply to M5 esp32 cam with solar charging out of the box on Sat, 26 Nov 2022 10:27:09 GMT]]></title><description><![CDATA[<p dir="auto">I'm using three timer cams with a tiny solar panel, lipo battery and a TP4056 as a charge regulator.<br />
I've soldered a diode between the solar panel and TP4056 to avoid battery drain in the dark. The camera's are in a remote location, and are functioning more than a month without a problem. The battery voltage is around 4.15 volt, so still almost completely full.</p>
]]></description><link>https://community.m5stack.com/post/19388</link><guid isPermaLink="true">https://community.m5stack.com/post/19388</guid><dc:creator><![CDATA[jvdpol]]></dc:creator><pubDate>Sat, 26 Nov 2022 10:27:09 GMT</pubDate></item></channel></rss>
