<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickC Plus cant drive an Adafruit sensor module (3.3V) through the Grove port using the Grove to STEMMA QT adapter.]]></title><description><![CDATA[<p dir="auto">Hi everyone, I cant seem to drive the STEMMA QT sensor modules that I have using the Grove to Stemma QT cable adapter sold by M5Stack through the Grove port of the M5StickC Plus board. Funnily enough, the M5StickC Plus's Grove port is able to drive an Ultrasonic sensor from M5Stack that needs 5V to run it. I would appreciate any kind of help cause I'm out of ideas already. Thank you in advance.</p>
<p dir="auto">Regards,<br />
Ameer</p>
]]></description><link>https://community.m5stack.com/topic/4777/m5stickc-plus-cant-drive-an-adafruit-sensor-module-3-3v-through-the-grove-port-using-the-grove-to-stemma-qt-adapter</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 06:20:43 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4777.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 04 Nov 2022 08:57:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickC Plus cant drive an Adafruit sensor module (3.3V) through the Grove port using the Grove to STEMMA QT adapter. on Fri, 04 Nov 2022 10:36:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ameero95" aria-label="Profile: ameero95">@<bdi>ameero95</bdi></a> said in <a href="/post/19195">M5StickC Plus cant drive an Adafruit sensor module (3.3V) through the Grove port using the Grove to STEMMA QT adapter.</a>:</p>
<p dir="auto">STEMMA QT</p>
<p dir="auto">try level shifter maybe?</p>
]]></description><link>https://community.m5stack.com/post/19196</link><guid isPermaLink="true">https://community.m5stack.com/post/19196</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Fri, 04 Nov 2022 10:36:06 GMT</pubDate></item></channel></rss>
