<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickC Driver problem ?]]></title><description><![CDATA[<p dir="auto">Hello to all,<br />
I have just registered on the forum and I need your help.<br />
I have just bought an M5StickC and a Core 2.<br />
I can't get them to connect to M5 burner ("Check your COM and retry")<br />
I am running Windows and the driver is installed (FTDI 2.12.36.4)<br />
<img src="ziqman.free.fr/photos/01.JPG" alt="device manager" class=" img-fluid img-markdown" /><br />
<img src="ziqman.free.fr/photos/02.JPG" alt="driver" class=" img-fluid img-markdown" /><br />
What did I miss?<br />
Thanks in advance,<br />
David</p>
]]></description><link>https://community.m5stack.com/topic/4792/m5stickc-driver-problem</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 16:00:24 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4792.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 10 Nov 2022 15:30:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickC Driver problem ? on Sun, 13 Nov 2022 11:26:10 GMT]]></title><description><![CDATA[<p dir="auto">I am a little ashamed, it was not a driver problem.<br />
In M5burner I didn't give the information about the wifi which prevented me to burn my M5Stick. It's confusing, the error message is about a port problem.<br />
Thank you all for your answers</p>
]]></description><link>https://community.m5stack.com/post/19286</link><guid isPermaLink="true">https://community.m5stack.com/post/19286</guid><dc:creator><![CDATA[David95]]></dc:creator><pubDate>Sun, 13 Nov 2022 11:26:10 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC Driver problem ? on Sat, 12 Nov 2022 17:50:09 GMT]]></title><description><![CDATA[<p dir="auto">Im having the same issue with my M5stick. I have updated the FTDI driver to the most recent driver. I am able to get them to burn by manually selecting the correct COM port. But I am unable to read/write the device file structure through USB/VS Code/Arduino IDE's.</p>
<p dir="auto">I have followed instructions set by M5Stack/FTDI to a tee, but am still unable to get the M5StickC to work in USB mode properly. I have reset the device multiple times, re-installed drivers, re-flashed, but unfortunately nothing is working.</p>
<p dir="auto">In VSCODE when I select my M5stack it doesnt show the file structure, but if I click "COM" in the lower left corner and reset the device it works. So from what I gather it is able to write to the device but not read the device.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Ive done some searching and I am unable to find the chaser FTDI driver. Do you have a link or thread I could check out so that I can give it a shot?</p>
]]></description><link>https://community.m5stack.com/post/19275</link><guid isPermaLink="true">https://community.m5stack.com/post/19275</guid><dc:creator><![CDATA[theaeropath]]></dc:creator><pubDate>Sat, 12 Nov 2022 17:50:09 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC Driver problem ? on Fri, 11 Nov 2022 06:27:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/david95" aria-label="Profile: david95">@<bdi>david95</bdi></a> During covid, the FTDI chip was changed in several models requiring the user of a second driver needing to be installed.<br />
You need to install the chaser FTDI driver.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/konacurrents" aria-label="Profile: konacurrents">@<bdi>konacurrents</bdi></a> I have the core 2 running OK on the M1 Mac Not all USB cables are the same and I'm connecting to the Mac via a Satechi IO hub.</p>
]]></description><link>https://community.m5stack.com/post/19259</link><guid isPermaLink="true">https://community.m5stack.com/post/19259</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 11 Nov 2022 06:27:49 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC Driver problem ? on Thu, 10 Nov 2022 21:52:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/david95" aria-label="Profile: david95">@<bdi>david95</bdi></a> I'm using Mac and can get the M5StickCplus working nicely. But cannot get the Core2 to connect over the serial port. I have had issues with the USB-C and power on some ESP devices. You might play with different cables, such as USB-A to USB-C vs straight UCB-C.</p>
]]></description><link>https://community.m5stack.com/post/19256</link><guid isPermaLink="true">https://community.m5stack.com/post/19256</guid><dc:creator><![CDATA[konacurrents]]></dc:creator><pubDate>Thu, 10 Nov 2022 21:52:33 GMT</pubDate></item></channel></rss>
