<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wiring for M5Stack Core2 and 4 channel relay module]]></title><description><![CDATA[<p dir="auto">Hello I just acquired the M5Stack Core 4 and want to connect it to a 4 channel relay.<br />
I see that below the device there is a table which explains the name for each of the pins,<br />
My question is which GPIO pins do you recommend me to use to control the signals for each channel?<br />
I'm thinking on using G19, G33, G22 and G14 for this purpose but I'm not sure if they're suitable for this purpose, you can correct me if I'm wrong.</p>
<p dir="auto">Thanks in advance,<br />
Jorge</p>
]]></description><link>https://community.m5stack.com/topic/4795/wiring-for-m5stack-core2-and-4-channel-relay-module</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 18:45:41 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4795.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 11 Nov 2022 02:02:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wiring for M5Stack Core2 and 4 channel relay module on Fri, 11 Nov 2022 08:17:38 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/seguidor777" aria-label="Profile: seguidor777">@<bdi>seguidor777</bdi></a></p>
<p dir="auto">the M5Core2 talks to the 4 channel relay module via <a href="https://en.wikipedia.org/wiki/I%C2%B2C" target="_blank" rel="noopener noreferrer nofollow ugc">I2C</a> which only requires 2 wires. Check out the <a href="https://docs.m5stack.com/en/module/4relay" target="_blank" rel="noopener noreferrer nofollow ugc">documentation</a>. Also have a look at the <a href="https://github.com/m5stack/M5Module-4Relay/tree/main/examples/Module_4RELAY_M5Core2" target="_blank" rel="noopener noreferrer nofollow ugc">example</a>.</p>
]]></description><link>https://community.m5stack.com/post/19262</link><guid isPermaLink="true">https://community.m5stack.com/post/19262</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 11 Nov 2022 08:17:38 GMT</pubDate></item></channel></rss>
