<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ESPNow module not available. Alternatives?]]></title><description><![CDATA[<p dir="auto">I am using UIFlow to try to get two-way communication Between three m5Stack core 2. ESPNow would have done so, but i get error saying that the ESPNow module is not valid. What other alternatives are there?</p>
]]></description><link>https://community.m5stack.com/topic/4801/espnow-module-not-available-alternatives</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:21:09 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4801.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 13 Nov 2022 09:33:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ESPNow module not available. Alternatives? on Tue, 15 Nov 2022 12:05:28 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/slow-moose" aria-label="Profile: slow-moose">@<bdi>slow-moose</bdi></a></p>
<p dir="auto">which UIFlow firmware version is running on your M5Core2?</p>
<p dir="auto">I can use ESPNow blocks from the UIFlow online version 1.10.8 just fine on my M5Core2 running UIFlow firmware 1.10.8.</p>
<p dir="auto">You can use M5Burner from <a href="https://docs.m5stack.com/en/download" target="_blank" rel="noopener noreferrer nofollow ugc">here</a> to update the UIFlow firmware on your M5Core2.</p>
]]></description><link>https://community.m5stack.com/post/19305</link><guid isPermaLink="true">https://community.m5stack.com/post/19305</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 15 Nov 2022 12:05:28 GMT</pubDate></item><item><title><![CDATA[Reply to ESPNow module not available. Alternatives? on Tue, 15 Nov 2022 10:00:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slow-moose" aria-label="Profile: slow-moose">@<bdi>slow-moose</bdi></a> ok, I found a way to use esp-now.<br />
When using ESPNow in the browser version of UIFlow, it imports: <em>from libs.m5_espnow import M5ESPNOW</em> which does not work. It says that the module does not exist.<br />
But when using the downloaded version of UIFlow, it imports instead <em>import espnow</em> and <em>import wifiCfg</em>, which does work...</p>
]]></description><link>https://community.m5stack.com/post/19304</link><guid isPermaLink="true">https://community.m5stack.com/post/19304</guid><dc:creator><![CDATA[slow-moose]]></dc:creator><pubDate>Tue, 15 Nov 2022 10:00:43 GMT</pubDate></item></channel></rss>
