<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Missing info about emoji]]></title><description><![CDATA[<p dir="auto">Running the on line version of UiFlow 1.10.8 for coding, having burned UIflow to my core2 , I have some questions about using Emoji.</p>
<p dir="auto">in the GUI you can drag and drop a emoji grid, or a block that sets a specific block in a grid to a color. This is a great start, but there are no blocks for setting the background image , size or anything else.</p>
<p dir="auto">If you look at the python code , you can see : emoji0 = Emoji(7, 7, 15, 9)   .. I've searched for hours on google but no where can I find the syntax for this. Through  trial and error I found that the first two digits are the number of blocks in the grid ( x,y ) but the last two seem to be some kind of scaling of the grid size or something I'm not sure of. Likewise I can find no reference to setting the background image, or doing anything else with the module. The most I can find is how to use unicode to display existing emoji.</p>
<p dir="auto">Where are the docs for this ? The only docs I can find stick to using blockly, and do no tell you HOW to change the background image or what that first command does, but they do mention it.</p>
]]></description><link>https://community.m5stack.com/topic/4829/missing-info-about-emoji</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:34:51 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4829.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 22 Nov 2022 11:18:57 GMT</pubDate><ttl>60</ttl></channel></rss>
