<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PIR motion sensor compatibility with LAN W5500 Proto Module]]></title><description><![CDATA[<p dir="auto">Hi there,</p>
<p dir="auto">I'm trying to connect a PIR motion Sensor to a core device which is connected to the LAN W5500 Proto Module for POE. The issue is the PIR motion sensor uses port B which is removed when the LAN device is added. I'm wondering if there is a another way I can connect the PIR device.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://community.m5stack.com/topic/4848/pir-motion-sensor-compatibility-with-lan-w5500-proto-module</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 08:17:56 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4848.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 29 Nov 2022 09:51:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PIR motion sensor compatibility with LAN W5500 Proto Module on Tue, 29 Nov 2022 22:39:34 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/btrex" aria-label="Profile: btrex">@<bdi>btrex</bdi></a></p>
<p dir="auto">not sure I understand why the LAN module removes port B. Do you mean the LAN module uses the GPIOs normally used for port B?</p>
<p dir="auto">Anyways, if you are using an M5Core2 device this <a href="https://docs.m5stack.com/en/module/extport_for_core2" target="_blank" rel="noopener noreferrer nofollow ugc">module</a> might help.</p>
<p dir="auto">And for an M5Stack device the bus <a href="https://shop.m5stack.com/collections/m5-modules/products/bus-module" target="_blank" rel="noopener noreferrer nofollow ugc">module</a> might be helpful as it exposes all pins.</p>
]]></description><link>https://community.m5stack.com/post/19411</link><guid isPermaLink="true">https://community.m5stack.com/post/19411</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 29 Nov 2022 22:39:34 GMT</pubDate></item></channel></rss>
