<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PaHub with Hall sensor]]></title><description><![CDATA[<p dir="auto">Hello,<br />
i cant connect Hall sensor A3144E to Pa.Hub 9548AP on my M5Stack Core 2.</p>
<p dir="auto">What is a solution to use it ??</p>
<p dir="auto">Regard Kamil</p>
]]></description><link>https://community.m5stack.com/topic/4870/pahub-with-hall-sensor</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:06:09 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4870.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 07 Dec 2022 17:01:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PaHub with Hall sensor on Fri, 09 Dec 2022 07:45:31 GMT]]></title><description><![CDATA[<p dir="auto">Ehhhh<br />
Anotcher anomaly i use Pb.Hub and i connect wind speed meter to ch0 and Hall sensor to ch1.<br />
I use digitalRead from ch0 to read IO 1 for speed meter and digitaRead ch1 read IO 1 to read hall<br />
AND signal is mixed for both. I get readings from windspped meter when i use hall and hall reads inputs when i blow to windspeed meter. When i use both i get stupid info :/</p>
]]></description><link>https://community.m5stack.com/post/19491</link><guid isPermaLink="true">https://community.m5stack.com/post/19491</guid><dc:creator><![CDATA[Kivlow]]></dc:creator><pubDate>Fri, 09 Dec 2022 07:45:31 GMT</pubDate></item><item><title><![CDATA[Reply to PaHub with Hall sensor on Thu, 08 Dec 2022 06:56:40 GMT]]></title><description><![CDATA[<p dir="auto">Ok i try to connect this way :<br />
core 2 -&gt; Pb.hub -&gt; hall sensor<br />
and i cant in UiFlow  to set the hall sensor to pb.hub i get only grove.<br />
See picture<br />
<img src="/assets/uploads/files/1670482435059-bug-pbhub-hall.jpg" alt="0_1670482434710_bug - pbhub hall.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">And another wired thing - when i use Pa.Hub with ENV III i get temp and humidity ok but pressure is -4826090,3. I cant get negativ pressure :&gt;<br />
When i connect direct to core 2 i get right value.</p>
]]></description><link>https://community.m5stack.com/post/19477</link><guid isPermaLink="true">https://community.m5stack.com/post/19477</guid><dc:creator><![CDATA[Kivlow]]></dc:creator><pubDate>Thu, 08 Dec 2022 06:56:40 GMT</pubDate></item><item><title><![CDATA[Reply to PaHub with Hall sensor on Thu, 08 Dec 2022 06:26:38 GMT]]></title><description><![CDATA[<p dir="auto">PaHub or Port A Hub is for use with I2C devices.<br />
Hall Unit is a Pb Device aka Port B Device (the connector collar tell you what port it connect to) for the Hall sensor you need a PbHub.</p>
]]></description><link>https://community.m5stack.com/post/19476</link><guid isPermaLink="true">https://community.m5stack.com/post/19476</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 08 Dec 2022 06:26:38 GMT</pubDate></item></channel></rss>
