<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How do I update NB-IoT Unit Global (SIM7020G) firmware?]]></title><description><![CDATA[<p dir="auto">The NB-IoT Unit Global (SIM7020G) has firmware 1910B03SIM7020G and there are some functions that are not working, but are working on the Atom DTU NB-IoT Kit Global (SIM7020G) which has firmware 1910B06SIM7020G.</p>
<p dir="auto">Does anyone know the process to update the firmware?</p>
<p dir="auto">I have contacted SIMCOM support, and they have sent me a tool, and the latest firmware 1910B08SIM7020G, but I can't get the update working, or know what I am supposed to do.</p>
<p dir="auto">I have tried connecting the NB-IoT Unit directly to my computer, using a USB-Serial converter, wired direct to TX/RX (and GND).</p>
<p dir="auto">The converter only has 3.3V, so I also have an external 5V supply.</p>
<p dir="auto">When it is all connected, I can use a terminal program to directly connect to the modem, and send AT commands.</p>
<p dir="auto">However I try running their update software and it can't connect.</p>
<p dir="auto">Does anyone know the correct procedure?</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://community.m5stack.com/topic/4879/how-do-i-update-nb-iot-unit-global-sim7020g-firmware</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 20:36:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4879.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 10 Dec 2022 10:40:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How do I update NB-IoT Unit Global (SIM7020G) firmware? on Sat, 10 Dec 2022 11:29:28 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/sgryphon" aria-label="Profile: sgryphon">@<bdi>sgryphon</bdi></a></p>
<p dir="auto">from what I can tell there are two (three?) options to update SIM7020 firmware:</p>
<li>using UART<strong>2</strong> (pins 22, 23) with a <strong>full</strong> firmware file</li>
<li>using OTA with a <strong>delta</strong> firmware file</li>
<p dir="auto">the procedure is described <a href="https://www.waveshare.com/wiki/File:SIM7020G_Hardware_Design_V1.00.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">here</a> and <a href="https://www.waveshare.com/wiki/File:SIM7020_Series_FOTA_Application_Note_V1.01.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
<p dir="auto">There is something written about FOTA in the <a href="https://www.waveshare.com/w/upload/a/a4/SIM7020_Series_AT_Command_Manual_V1.03.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">AT document</a> as well. It sounds like one could download the delta firmware directly from the SIMCOM? server?</p>
<p dir="auto">Sorry, I don't know the exact process to update firmware but I am curious myself so please keep us (me) updated about what you find.</p>
]]></description><link>https://community.m5stack.com/post/19502</link><guid isPermaLink="true">https://community.m5stack.com/post/19502</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 10 Dec 2022 11:29:28 GMT</pubDate></item></channel></rss>
