<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Latest Firmware for Atom Lite]]></title><description><![CDATA[<p dir="auto">Does the Atom Lite come with the latest firmware installed or is there a newer version than Micropython-1.12? I found some firmware on the MicroPython site but when I load it everything appears to go as expected but then I can't reach my Atom Lite via VSCode afterwards. I can put everything back using M5Burner but wanted the newer firmware. Has anyone else trien to update the firmware and if so where did you find it and what version did you use? Thanks in advance.</p>
<p dir="auto">Here are the results of my attemp showing no errors:</p>
<p dir="auto">python -m esptool --chip esp32 --port COM11 write_flash -z 0x1000 M5STACK_ATOM-20220618-v1.19.1.bin<br />
<a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a> v3.2<br />
Serial port COM11<br />
Connecting....<br />
Chip is ESP32-PICO-D4 (revision 1)<br />
Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, VRef calibration in efuse, Coding Scheme None<br />
Crystal is 40MHz<br />
MAC: 4c:75:25:d7:8e:90<br />
Uploading stub...<br />
Running stub...<br />
Stub running...<br />
Flash will be erased from 0x00001000 to 0x0017cfff...<br />
Compressed 1554752 bytes to 1026054...<br />
Wrote 1554752 bytes (1026054 compressed) at 0x00001000 in 93.4 seconds (effective 133.1 kbit/s)...<br />
Hash of data verified.</p>
<p dir="auto">Leaving...<br />
Hard resetting via RTS pin...</p>
]]></description><link>https://community.m5stack.com/topic/4884/latest-firmware-for-atom-lite</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:14:00 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4884.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 11 Dec 2022 17:15:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Latest Firmware for Atom Lite on Wed, 14 Dec 2022 08:39:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wwhite" aria-label="Profile: wwhite">@<bdi>wwhite</bdi></a> don’t know about circuit python but mainstream python can be installed using the Thonny IDE<br />
I have 1.19 running on M5Stamps at the moment but you have to remember that Mainsteam MP won’t have the M5Stack specific libraries</p>
]]></description><link>https://community.m5stack.com/post/19550</link><guid isPermaLink="true">https://community.m5stack.com/post/19550</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 14 Dec 2022 08:39:48 GMT</pubDate></item><item><title><![CDATA[Reply to Latest Firmware for Atom Lite on Tue, 13 Dec 2022 16:15:10 GMT]]></title><description><![CDATA[<p dir="auto">I wanted to try this CircuitPython <a href="https://circuitpython.org/board/m5stack_atom_lite/" target="_blank" rel="noopener noreferrer nofollow ugc">https://circuitpython.org/board/m5stack_atom_lite/</a></p>
<p dir="auto">or</p>
<p dir="auto">v1.9.1 from here <a href="https://micropython.org/download/M5STACK_ATOM/" target="_blank" rel="noopener noreferrer nofollow ugc">https://micropython.org/download/M5STACK_ATOM/</a></p>
<p dir="auto">Thanks for responding.</p>
]]></description><link>https://community.m5stack.com/post/19540</link><guid isPermaLink="true">https://community.m5stack.com/post/19540</guid><dc:creator><![CDATA[wwhite]]></dc:creator><pubDate>Tue, 13 Dec 2022 16:15:10 GMT</pubDate></item><item><title><![CDATA[Reply to Latest Firmware for Atom Lite on Mon, 12 Dec 2022 07:21:33 GMT]]></title><description><![CDATA[<p dir="auto">Are you installing the core Micropython for the ESP32 Pico D4?<br />
Core MP does not have any of the M5Stack libraries.</p>
]]></description><link>https://community.m5stack.com/post/19521</link><guid isPermaLink="true">https://community.m5stack.com/post/19521</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 12 Dec 2022 07:21:33 GMT</pubDate></item></channel></rss>
