<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Detect walking direction using 2 PIR units]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I'm planning to buy two M5stack PIR units and a pb.hub (I'll connect this to an M5stickCplus)<br />
Do these PIR sensors trigger consistently (always the same sensitivity)?<br />
I need to know this because I want to use the time difference between the triggering of these two sensors (mounted in a distance of ~10cm away from each other) to detect in which direction a person walks.</p>
Aaron</p>
]]></description><link>https://community.m5stack.com/topic/4895/detect-walking-direction-using-2-pir-units</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 15:16:10 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4895.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Dec 2022 17:20:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Detect walking direction using 2 PIR units on Wed, 14 Dec 2022 18:37:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aeisele55" aria-label="Profile: aeisele55">@<bdi>aeisele55</bdi></a> I don't think PIR's would be suitable for that as the detection range would result in both being triggered.<br />
You may be better off with a pair of TOFS or laser beam and receivers.</p>
]]></description><link>https://community.m5stack.com/post/19558</link><guid isPermaLink="true">https://community.m5stack.com/post/19558</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 14 Dec 2022 18:37:49 GMT</pubDate></item></channel></rss>
