<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mysterious power down on CORE2-AWS]]></title><description><![CDATA[<p dir="auto">I'm running a CORE2-AWS , powered by USB , with two 180 servos and an OLED module.</p>
<p dir="auto">My software does a number of small tasks, nothing too intensive, and the servos do not run at the same time, or very long. The curious part is that at first I had only one servo - and it's job was to rotate the CORE2-AWS while it showed an avatar ( Stack-Chan ). After adding a second servo ( with provided capacitors and breadboard ) suddenly the system had an odd habit of turning itself off w/out any errors or warnings. I tried swapping ports around, but that didn't change anything. I thought also that maybe one of the servos was defective so I swapped it out but again after some time of running it turned off.</p>
<p dir="auto">MY current thoughts are that it may be a power issue, but I can not find any info on how to attach supplemental power, nor a recommendation as to what M5STACK module that can take external power that would fit my needs. IT has also been suggested that it might be a software issue, but I can not see any errors, and I have reduced the code quite a bit to like 1 or 2 basic functions and it still happens. If it is a matter of power/overheating/somethign else there are no error logs to look at to see why it shut down.</p>
<p dir="auto">Open to suggestions! Any thoughts ?</p>
]]></description><link>https://community.m5stack.com/topic/4960/mysterious-power-down-on-core2-aws</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:52:31 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4960.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 09 Jan 2023 13:33:13 GMT</pubDate><ttl>60</ttl></channel></rss>
