<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Using M5stack IR module in UART mode]]></title><description><![CDATA[<p dir="auto">Dear all,</p>
<p dir="auto">following <a href="https://community.m5stack.com/topic/4943/smart-meter-project-using-esphome">this</a> question, I built a simple setup to build a smart meter IR reading system. I use the <a href="https://docs.m5stack.com/en/core/atom_lite" target="_blank" rel="noopener noreferrer nofollow ugc">M5stack ATOM lite</a>. Using an third-party IR reading head on pins 33 (RX) and 25 TX) switched to UART mode, I receive messages.</p>
<p dir="auto">Now a more mature setup would be the <a href="https://shop.m5stack.com/products/ir-unit" target="_blank" rel="noopener noreferrer nofollow ugc">M5stack IR module</a>. I bought one, connected it to the GROVE interface and simply changed the UART pins to those of the GROVE, i.e. pin 32 (RX) and 26 (TX).</p>
<p dir="auto">Unfortunately, I get no readings form the M5 IR module. On the UART debug, I only receive weird data.</p>
<p dir="auto">Is the M5 module maybe not usable for UART? Or is the GROVE port the issue (while the <a href="https://docs.m5stack.com/en/core/atom_lite" target="_blank" rel="noopener noreferrer nofollow ugc">docs</a> note that the port is available for UART)?</p>
<p dir="auto">Thanks for help!</p>
]]></description><link>https://community.m5stack.com/topic/4965/using-m5stack-ir-module-in-uart-mode</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 12:21:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4965.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 10 Jan 2023 11:54:14 GMT</pubDate><ttl>60</ttl></channel></rss>
