<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[uiflow 1.1 m5stick no api key]]></title><description><![CDATA[<p dir="auto">I loaded the new 1.1 firmware onto the stick and I set the ssid and password for the network. When the board resets it isn't showing the api key. I've tried a few times to go through this process but it just isn't showing up with the api info. The stick worked with the previous firmware. What can I do to get the info from the board. thanks</p>
]]></description><link>https://community.m5stack.com/topic/500/uiflow-1-1-m5stick-no-api-key</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:22:08 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/500.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 11 Jan 2019 07:33:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to uiflow 1.1 m5stick no api key on Sat, 12 Jan 2019 09:30:53 GMT]]></title><description><![CDATA[<p dir="auto">I've just taken several goes to write the firmware (I think my W7 laptop to blame).<br />
It kept getting stuck in bootloader mode and wouldn't leave.<br />
Finially got it to program and reset after pressing the on/off button twice.</p>
]]></description><link>https://community.m5stack.com/post/2463</link><guid isPermaLink="true">https://community.m5stack.com/post/2463</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 12 Jan 2019 09:30:53 GMT</pubDate></item><item><title><![CDATA[Reply to uiflow 1.1 m5stick no api key on Sat, 12 Jan 2019 08:12:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jpilarski" aria-label="Profile: jpilarski">@<bdi>jpilarski</bdi></a> Glad to hear it.</p>
]]></description><link>https://community.m5stack.com/post/2462</link><guid isPermaLink="true">https://community.m5stack.com/post/2462</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 12 Jan 2019 08:12:01 GMT</pubDate></item><item><title><![CDATA[Reply to uiflow 1.1 m5stick no api key on Sat, 12 Jan 2019 05:59:17 GMT]]></title><description><![CDATA[<p dir="auto">I think what was happening was, for some reason, <a href="http://flow.py" target="_blank" rel="noopener noreferrer nofollow ugc">flow.py</a> was never being loaded. I manually ran <a href="http://flow.py" target="_blank" rel="noopener noreferrer nofollow ugc">flow.py</a> from the console and it allowed the m5stick to finally go to the api key screen. I noticed in the code it mentions you can press button A to generate a new api key but for some reason it wasn't working. Anyways now it's good and I am successfully programming the stick as we speak. thanks</p>
]]></description><link>https://community.m5stack.com/post/2461</link><guid isPermaLink="true">https://community.m5stack.com/post/2461</guid><dc:creator><![CDATA[jpilarski]]></dc:creator><pubDate>Sat, 12 Jan 2019 05:59:17 GMT</pubDate></item><item><title><![CDATA[Reply to uiflow 1.1 m5stick no api key on Fri, 11 Jan 2019 20:52:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jpilarski" aria-label="Profile: jpilarski">@<bdi>jpilarski</bdi></a> No, he circled the "Stick" part of the file name.<br />
Give me 24 hours as my stick just turned up so I will see what happens tomorrow.<br />
Have you got arduino installed?<br />
You could try connecting with arduinos serial monitor to see if that works.</p>
]]></description><link>https://community.m5stack.com/post/2459</link><guid isPermaLink="true">https://community.m5stack.com/post/2459</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 11 Jan 2019 20:52:10 GMT</pubDate></item><item><title><![CDATA[Reply to uiflow 1.1 m5stick no api key on Fri, 11 Jan 2019 20:35:49 GMT]]></title><description><![CDATA[<p dir="auto">I am using 1.1.0 firmware for the stick (you circled 1.0.0 but I am assuming you meant 1.10). I am able to set the wifi after installing firmware but it never shows the screen with the api key. Can I get the api key in a repl shell or someother way because I do think it's working except it's not showing me the key.</p>
]]></description><link>https://community.m5stack.com/post/2458</link><guid isPermaLink="true">https://community.m5stack.com/post/2458</guid><dc:creator><![CDATA[jpilarski]]></dc:creator><pubDate>Fri, 11 Jan 2019 20:35:49 GMT</pubDate></item><item><title><![CDATA[Reply to uiflow 1.1 m5stick no api key on Fri, 11 Jan 2019 11:16:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jpilarski" aria-label="Profile: jpilarski">@<bdi>jpilarski</bdi></a></p>
<p dir="auto">Have you burt the stick firmware<br />
<img src="/assets/uploads/files/1547205381506-s.png" alt="0_1547205381740_s.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/2451</link><guid isPermaLink="true">https://community.m5stack.com/post/2451</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Fri, 11 Jan 2019 11:16:45 GMT</pubDate></item><item><title><![CDATA[Reply to uiflow 1.1 m5stick no api key on Fri, 11 Jan 2019 09:37:17 GMT]]></title><description><![CDATA[<p dir="auto">Have you loaded the correct firmware as there are several versions depending on base unit but the current version is 1.3</p>
]]></description><link>https://community.m5stack.com/post/2450</link><guid isPermaLink="true">https://community.m5stack.com/post/2450</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 11 Jan 2019 09:37:17 GMT</pubDate></item></channel></rss>
