<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Help with uiflow and max6675]]></title><description><![CDATA[<p dir="auto">Can i somehow to read temperature via uiflow?? in arduino i succeed</p>
]]></description><link>https://community.m5stack.com/topic/5017/help-with-uiflow-and-max6675</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 00:20:58 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5017.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 30 Jan 2023 23:35:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Help with uiflow and max6675 on Sat, 11 Feb 2023 13:17:53 GMT]]></title><description><![CDATA[<p dir="auto">i have just that MCP9600great</p>
<p dir="auto"><img src="/assets/uploads/files/1676119692050-abe5939f-a3ca-482e-a0a0-0bc08ef52c64-image-resized.png" alt="0_1676119689985_abe5939f-a3ca-482e-a0a0-0bc08ef52c64-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">is this suppose work that example setup? it show only 55,9 C and i2c address is right</p>
]]></description><link>https://community.m5stack.com/post/20057</link><guid isPermaLink="true">https://community.m5stack.com/post/20057</guid><dc:creator><![CDATA[TeacDance]]></dc:creator><pubDate>Sat, 11 Feb 2023 13:17:53 GMT</pubDate></item><item><title><![CDATA[Reply to Help with uiflow and max6675 on Tue, 31 Jan 2023 23:35:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teacdance" aria-label="Profile: teacdance">@<bdi>teacdance</bdi></a><br />
1-wire isn't supported in uiflow .. you will have to add an 1-wire to i2c converter:  DS2482  -&gt; <a href="https://community.m5stack.com/topic/1796/ui-flow-support-for-onewire-and-ds18x20/10">https://community.m5stack.com/topic/1796/ui-flow-support-for-onewire-and-ds18x20/10</a><br />
But you can use the MCP9600 with UIFlow (I2C-protocol).</p>
]]></description><link>https://community.m5stack.com/post/19976</link><guid isPermaLink="true">https://community.m5stack.com/post/19976</guid><dc:creator><![CDATA[crami25]]></dc:creator><pubDate>Tue, 31 Jan 2023 23:35:10 GMT</pubDate></item><item><title><![CDATA[Reply to Help with uiflow and max6675 on Tue, 31 Jan 2023 18:24:24 GMT]]></title><description><![CDATA[<p dir="auto">ok too hard for me.. i have k-type sensor 1-wire version too is that easier it use MAX31850K it's i2c</p>
]]></description><link>https://community.m5stack.com/post/19974</link><guid isPermaLink="true">https://community.m5stack.com/post/19974</guid><dc:creator><![CDATA[TeacDance]]></dc:creator><pubDate>Tue, 31 Jan 2023 18:24:24 GMT</pubDate></item><item><title><![CDATA[Reply to Help with uiflow and max6675 on Tue, 31 Jan 2023 13:03:04 GMT]]></title><description><![CDATA[<p dir="auto">Are you using the max6675 hooked up directly to a M5stack core ? UIFlow doesn't support SPI, but you can use Micropython as described in <a href="https://community.m5stack.com/topic/1845/micropython-spi">https://community.m5stack.com/topic/1845/micropython-spi</a></p>
<p dir="auto">The M5Stack Kmeter Unit uses the max6674 and an esp32 with dedicated firmware as a SPI to I2C in addition to a thermocouple reading to temperature converter. The M5Stack Kmeter Unit has a red grove connector (I2C) and is supported in UIFlow.<br />
<img src="/assets/uploads/files/1675170050773-a99c7001-e81e-45db-9f33-7fa0e4dfe330-image.png" alt="0_1675170049256_a99c7001-e81e-45db-9f33-7fa0e4dfe330-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/19972</link><guid isPermaLink="true">https://community.m5stack.com/post/19972</guid><dc:creator><![CDATA[crami25]]></dc:creator><pubDate>Tue, 31 Jan 2023 13:03:04 GMT</pubDate></item></channel></rss>
