<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Solved]uiflow new FW(v1.1.0) can&#x27;t writting.]]></title><description><![CDATA[<p dir="auto">I've executed <a href="http://flash.sh" target="_blank" rel="noopener noreferrer nofollow ugc">flash.sh</a> command. but catch following error.</p>
<pre><code class="language-sh">$ cd M5Burner-flow-only/firmwares/M5Flow/v1.1.0-en
$ ./flash.sh
usage: esptool write_flash [-h] [--erase-all]
                           [--flash_freq {keep,40m,26m,20m,80m}]
                           [--flash_mode {keep,qio,qout,dio,dout}]
                           [--flash_size FLASH_SIZE]
                           [--spi-connection SPI_CONNECTION] [--no-progress]
                           [--verify] [--compress | --no-compress]
                           &lt;address&gt; &lt;filename&gt; [&lt;address&gt; &lt;filename&gt; ...]
esptool write_flash: error: argument &lt;address&gt; &lt;filename&gt;: Detected overlap at address: 0x160000 for file: spiffs_image_0x170000.img
<p dir="auto">why?</p>
<p dir="auto">firmware version: v1.1.0-en<br />
hardware: M5Stack Basic<br />
pc os: macOS Mojave</p>
<p dir="auto">Please give me some advice.<br />
thanks.</p>
]]></description><link>https://community.m5stack.com/topic/505/solved-uiflow-new-fw-v1-1-0-can-t-writting</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 15:37:11 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/505.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 13 Jan 2019 04:08:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Solved]uiflow new FW(v1.1.0) can&#x27;t writting. on Tue, 15 Jan 2019 19:34:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heybin" aria-label="Profile: heybin">@<bdi>heybin</bdi></a></p>
<p dir="auto">While you are at it, please update the entire zip file for the Mac version of the M5Burner.  What is linked in <a href="http://flow.m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">flow.m5stack.com</a> today only goes up to v1.0.1.  I need v1.1.0 please.</p>
<p dir="auto"><a href="http://flow.m5stack.com/download/M5Burner_MacOS.zip" target="_blank" rel="noopener noreferrer nofollow ugc">http://flow.m5stack.com/download/M5Burner_MacOS.zip</a></p>
]]></description><link>https://community.m5stack.com/post/2520</link><guid isPermaLink="true">https://community.m5stack.com/post/2520</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Tue, 15 Jan 2019 19:34:44 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]uiflow new FW(v1.1.0) can&#x27;t writting. on Mon, 14 Jan 2019 02:30:17 GMT]]></title><description><![CDATA[<p dir="auto">sorry, i forgot to modify the mac file, need change <a href="http://flash.sh" target="_blank" rel="noopener noreferrer nofollow ugc">flash.sh</a> address 160000 -&gt; 170000</p>
]]></description><link>https://community.m5stack.com/post/2475</link><guid isPermaLink="true">https://community.m5stack.com/post/2475</guid><dc:creator><![CDATA[heybin]]></dc:creator><pubDate>Mon, 14 Jan 2019 02:30:17 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]uiflow new FW(v1.1.0) can&#x27;t writting. on Sun, 13 Jan 2019 08:33:53 GMT]]></title><description><![CDATA[<p dir="auto">Because you forgot to pass the additional parameters required to make it work.</p>
<p dir="auto">There is a slightly better version with a visual front end that can be downloaded from withing UIFlow but you need to disable the download security first using<br />
<code>sudo spctl --master-disable</code><br />
you then download the firmware loader and run it to install the firmware (you need to erase the ld firmware first before installing the new)<br />
and then type<br />
<code>sudo spctl --master-enable</code><br />
to reset the system security.</p>
<p dir="auto"><strong>Only do this when downloading the uiflow firmware program!</strong></p>
]]></description><link>https://community.m5stack.com/post/2469</link><guid isPermaLink="true">https://community.m5stack.com/post/2469</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 13 Jan 2019 08:33:53 GMT</pubDate></item></channel></rss>
