<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5STACK STATION PORT CONNECTORS]]></title><description><![CDATA[<p dir="auto">Hello,<br />
what are the connectors to be used for the side ports and the lower port (the orange one W/ the rs485) of the M5 stack station?<br />
I don't mean the code in you store, I mean what standard/ID are these connectors, I need to get them off digikey.</p>
<p dir="auto">thanks! :-)</p>
]]></description><link>https://community.m5stack.com/topic/5067/m5stack-station-port-connectors</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:49:30 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5067.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Feb 2023 14:23:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5STACK STATION PORT CONNECTORS on Wed, 22 Feb 2023 20:09:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/caterpillaraoz" aria-label="Profile: caterpillaraoz">@<bdi>caterpillaraoz</bdi></a> They do on the product page and the product document page.</p>
]]></description><link>https://community.m5stack.com/post/20163</link><guid isPermaLink="true">https://community.m5stack.com/post/20163</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 22 Feb 2023 20:09:12 GMT</pubDate></item><item><title><![CDATA[Reply to M5STACK STATION PORT CONNECTORS on Wed, 22 Feb 2023 10:49:14 GMT]]></title><description><![CDATA[<p dir="auto">thanks to all that replied</p>
<p dir="auto">@M5S: you should, as every industrial equipment provider, give clear info about the connectors to use. I need a code to slap into DigiKey search &amp; get the product!!! :-)</p>
]]></description><link>https://community.m5stack.com/post/20156</link><guid isPermaLink="true">https://community.m5stack.com/post/20156</guid><dc:creator><![CDATA[Caterpillaraoz]]></dc:creator><pubDate>Wed, 22 Feb 2023 10:49:14 GMT</pubDate></item><item><title><![CDATA[Reply to M5STACK STATION PORT CONNECTORS on Tue, 21 Feb 2023 18:26:45 GMT]]></title><description><![CDATA[<p dir="auto">HY2.0-4P or grove connectors,<br />
VH3.96 for the orange connectors.</p>
]]></description><link>https://community.m5stack.com/post/20154</link><guid isPermaLink="true">https://community.m5stack.com/post/20154</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 21 Feb 2023 18:26:45 GMT</pubDate></item><item><title><![CDATA[Reply to M5STACK STATION PORT CONNECTORS on Tue, 21 Feb 2023 00:49:11 GMT]]></title><description><![CDATA[<p dir="auto">You want UNbuckled "Grove" connectors to fit all M5Stack devices. For example, the M5StickC-Plus will accept both unbuckled and bucked connectors, but the Core2 will only accept an unbuckled connector. If you have the buckled type, you can always cut the clip off so it will fit.</p>
<p dir="auto">Generically, these connectors are called "HY2.0-4P" although nearly all vendors sell them as "Grove".</p>
<p dir="auto">There's no standard for the Vcc and logic levels! So make sure your devices match. M5Stack devices supply 5V on the red conductor, but the logic levels are 3.3V.</p>
]]></description><link>https://community.m5stack.com/post/20146</link><guid isPermaLink="true">https://community.m5stack.com/post/20146</guid><dc:creator><![CDATA[wsanders]]></dc:creator><pubDate>Tue, 21 Feb 2023 00:49:11 GMT</pubDate></item><item><title><![CDATA[Reply to M5STACK STATION PORT CONNECTORS on Mon, 20 Feb 2023 18:39:28 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://shop.m5stack.com/products/4pin-buckled-grove-cable:" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/4pin-buckled-grove-cable:</a><br />
Cables connecting the red grove port with units with a red grove connector (I2C),<br />
connecting the black grove port with units with a black grove connector (digital, analog),<br />
connecting the blue grove port with units with a blue grove connector (serial, RS432).</p>
]]></description><link>https://community.m5stack.com/post/20140</link><guid isPermaLink="true">https://community.m5stack.com/post/20140</guid><dc:creator><![CDATA[crami25]]></dc:creator><pubDate>Mon, 20 Feb 2023 18:39:28 GMT</pubDate></item></channel></rss>
