<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[m5go World Clock Problem]]></title><description><![CDATA[<p dir="auto">Hello</p>
<p dir="auto">I am trying to create a world clock on the m5go. But if I want to display several times at once, an error comes up after a few seconds because the m5go is overloaded. Is there a solution to this probelm?</p>
<p dir="auto">LG</p>
]]></description><link>https://community.m5stack.com/topic/5078/m5go-world-clock-problem</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 17:50:27 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5078.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Feb 2023 09:04:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to m5go World Clock Problem on Fri, 24 Feb 2023 08:08:26 GMT]]></title><description><![CDATA[<p dir="auto">What exactly is the issue?<br />
What hardware are you using?<br />
What error messages are you getting?<br />
What code are you using?<br />
What have you tried to fix the issue?</p>
]]></description><link>https://community.m5stack.com/post/20178</link><guid isPermaLink="true">https://community.m5stack.com/post/20178</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 24 Feb 2023 08:08:26 GMT</pubDate></item><item><title><![CDATA[Reply to m5go World Clock Problem on Fri, 24 Feb 2023 06:41:03 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
your question reads like "my car will not start, what shall I do?". The standard answer to that question is "buy a new car" even if the solution would be as easy as "turn the key" or "fill some gasoline".<br />
From your description we know you want to have a world clock and you have a m5go. What is missing:</p>
<li>The environment you use to code your clock</li>
<li>Your code which seems to be the problem</li>
<li>the exact error message or a picture of what you call "overloaded"</li>
<p dir="auto">please read this post first: <a href="https://forum.m5stack.com/topic/535/forum-rules-read-this-first-before-posting" target="_blank" rel="noopener noreferrer nofollow ugc">https://forum.m5stack.com/topic/535/forum-rules-read-this-first-before-posting</a></p>
]]></description><link>https://community.m5stack.com/post/20177</link><guid isPermaLink="true">https://community.m5stack.com/post/20177</guid><dc:creator><![CDATA[holofloh]]></dc:creator><pubDate>Fri, 24 Feb 2023 06:41:03 GMT</pubDate></item></channel></rss>
