<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Network Module object does not have attribute LAN]]></title><description><![CDATA[<p dir="auto">I would like to use my M5Stack as a http Server. That works great with internal WiFi, but not via Ethernet.<br />
The solution is programmed in Micropython.</p>
<p dir="auto"><strong>The following code does not work on my M5Stack Fire with W5500 Base Module:</strong><br />
--&gt; line 4: in &lt;module&gt; AttributeError: 'module' object has no attribute 'LAN'</p>
<p dir="auto">import network<br />
import socket</p>
<p dir="auto">lan = network.LAN(mdc=23, mdio=18, power=21, phy_type=network.PHY_W5500, phy_addr=0)</p>
<p dir="auto">lan.ifconfig(('192.168.50.108', '255.255.255.0', '192.168.50.1', '255.255.255.0'))<br />
lan.active(True)</p>
<p dir="auto">sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)<br />
sock.bind(('192.168.50.108', 8080))</p>
<p dir="auto">sock.listen(1)<br />
while True:<br />
conn, addr = sock.accept()<br />
print('Connection from:', addr)<br />
conn.sendall('Hello, world!')<br />
conn.close()</p>
]]></description><link>https://community.m5stack.com/topic/5080/network-module-object-does-not-have-attribute-lan</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 21:11:50 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5080.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 Feb 2023 06:10:52 GMT</pubDate><ttl>60</ttl></channel></rss>
