<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Custom Firmware but NOT published &#x2F; public]]></title><description><![CDATA[<p dir="auto">Hi All</p>
<p dir="auto">I have some some custom code for the Timer Camera and I'd like to burn my .bin file using m5Burner tool but I don't want it publicly listed/available. Is this possible?</p>
<p dir="auto">The reason I'd like to use the tool is</p>
<li>I'll be getting someone else to build my devices and load the firmware and want to just supply a .bin file.</li>
<li>I'm using the TimerCamRTSP official build to initially calibrate/focus the camera.</li>
<li>I then need to re-flashing with my own code (I don't have or need a camera stream once deployed).<br />
It'd be nice if this was in the one tool.</li>
<p dir="auto">I can see how to add my .bin file but it 'appears' to publish it for everyone to see. Is this correct and can I restrict access to it?</p>
Rob</p>
]]></description><link>https://community.m5stack.com/topic/5086/custom-firmware-but-not-published-public</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 22:51:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5086.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 26 Feb 2023 07:05:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Custom Firmware but NOT published &#x2F; public on Sun, 26 Feb 2023 21:15:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> said in <a href="/post/20200">Custom Firmware but NOT published / public</a>:</p>
<p dir="auto">ESP-IDY</p>
<p dir="auto">Thanks but I'm asking about burning my .bin file via the m5burner tool specifically. The interface is nice and simple for a student or inexperienced employee to use and I'm using it already to burn the RTSP build before I burn mine.</p>
<p dir="auto">I'm using VScode atm and am able to burn my build with that but would like a single tool for both burns to simplify the process.</p>
]]></description><link>https://community.m5stack.com/post/20207</link><guid isPermaLink="true">https://community.m5stack.com/post/20207</guid><dc:creator><![CDATA[RavenCo]]></dc:creator><pubDate>Sun, 26 Feb 2023 21:15:30 GMT</pubDate></item><item><title><![CDATA[Reply to Custom Firmware but NOT published &#x2F; public on Sun, 26 Feb 2023 17:41:40 GMT]]></title><description><![CDATA[<p dir="auto">Yes it's possible, you need to install ESP-IDY following the guide on there website, configure the tools and then just run the eps-tool or <a href="http://idf.py" target="_blank" rel="noopener noreferrer nofollow ugc">idf.py</a> to upload the bin file to the camera.</p>
]]></description><link>https://community.m5stack.com/post/20200</link><guid isPermaLink="true">https://community.m5stack.com/post/20200</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 26 Feb 2023 17:41:40 GMT</pubDate></item></channel></rss>
