<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RX&#x2F;TX voltages for Atom Lite]]></title><description><![CDATA[<p dir="auto">Hi, new to this forum and a bit of a newbie to hardware-level hacking … so forgive me if I’m asking a stupid question.</p>
<p dir="auto">I want to connect my air conditioning unit (mitsubishi heat pump) to our wifi network using an Atom Lite. The ac unit has a serial connector delivering 5V power and also using 5V signalling for RX/TX via a JST PA connector. To keep it neat, I was going to use a USB-C cable with breakout wires and a JST connector to wire them directly.</p>
<p dir="auto">I’m aware that the PICO board in the Atom Lite uses 3.3V for signalling, but there appears to be a regulator in the circuit board diagram for the USB-C port. I <em>think</em> that means I can connect the ac unit RX/TX pins directly to the USB DP/DM wires.</p>
<p dir="auto">Is anyone able to confirm?</p>
<p dir="auto">In case it’s useful, I was planning to use esphome to flash the Atom Lite based on this code: <a href="https://github.com/geoffdavis/esphome-mitsubishiheatpump" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/geoffdavis/esphome-mitsubishiheatpump</a>. The producer of the underlying arduino software noted the need for regulators for other ESP boards: <a href="https://github.com/SwiCago/HeatPump#other-part-suggestions" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/SwiCago/HeatPump#other-part-suggestions</a>.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://community.m5stack.com/topic/5106/rx-tx-voltages-for-atom-lite</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 10:40:47 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5106.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Mar 2023 05:13:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RX&#x2F;TX voltages for Atom Lite on Tue, 07 Mar 2023 05:34:05 GMT]]></title><description><![CDATA[<p dir="auto">from what im aware the pins are 3v3 logic and so you need a 5v&gt;3v3 logic shifter board like this: <a href="https://www.amazon.co.uk/Youmile-Channels-Converter-Bi-Directional-Shifter/dp/B08BZ8K7YR/ref=sr_1_2_sspa?crid=1YGIYN9553SC8&amp;keywords=logic+shifter&amp;qid=1678167168&amp;sprefix=logic+shifter%2Caps%2C74&amp;sr=8-2-spons&amp;sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&amp;psc=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.amazon.co.uk/Youmile-Channels-Converter-Bi-Directional-Shifter/dp/B08BZ8K7YR/ref=sr_1_2_sspa?crid=1YGIYN9553SC8&amp;keywords=logic+shifter&amp;qid=1678167168&amp;sprefix=logic+shifter%2Caps%2C74&amp;sr=8-2-spons&amp;sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&amp;psc=1</a></p>
<p dir="auto">between the M5Atom and the zircon unit.</p>
]]></description><link>https://community.m5stack.com/post/20260</link><guid isPermaLink="true">https://community.m5stack.com/post/20260</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 07 Mar 2023 05:34:05 GMT</pubDate></item></channel></rss>
