<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I have the same issue - blank screen on M5Core2]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/4748/m5core-blank-screen">M5Core - blank screen</a></p>
<p dir="auto">Hello, I have the same issue with M5Core2.  The device worked for a couple of days, but now screen is blank.  I've tried the following all without success: (i) erasing flash and reloading the UI-Flow Core2 firmware, (ii) erasing flash and loading the Core2FactoryTest, (iii)  erasing flash and loading the M5Core2TouchPanelRecovery, (iii) used "Firmware Exporter" from M5Burner to save the 16MB binary image of a good working M5Core2 and then used ESPTools to burn that image onto the broken M5Core2.</p>
<p dir="auto">I am curious if you have found a solution to your similar blank screen problem.</p>
]]></description><link>https://community.m5stack.com/topic/5109/i-have-the-same-issue-blank-screen-on-m5core2</link><generator>RSS for Node</generator><lastBuildDate>Mon, 04 May 2026 10:34:00 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5109.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Mar 2023 22:56:42 GMT</pubDate><ttl>60</ttl></channel></rss>
