<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Operational Temperature Range M5Stamp ESP32S3]]></title><description><![CDATA[<p dir="auto">You guys came so close to making a prefect product with the M5Stamp ESP32S3.<br />
Though there are some things that IMHO made no sense.<br />
#1) The button on top. I would lean toward useless, or at the very least tied to reset.<br />
I would rather see it removed, use the money you saved on the button, and put it towards getting a lower temp range.</p>
<p dir="auto">#2) By rating this for 0 Deg. C. You just limited yourself to indoor applications only!<br />
Whatever part is in there that is the limiting factor,  replace it with something else.</p>
<p dir="auto">Also, when checking out you should add options for including 2.54mm or 1.27mm headers.<br />
The ones we bought came with the 4 pin &amp; the 2.54mm headers. Both of which we will never use.</p>
]]></description><link>https://community.m5stack.com/topic/5139/operational-temperature-range-m5stamp-esp32s3</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 13:42:20 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5139.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Mar 2023 03:43:07 GMT</pubDate><ttl>60</ttl></channel></rss>
