<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Watering pump does not work]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I have 8 watering pumps that I use to teach kids to code with the M5s. Two of them do not work. Water does not flow, event though they make a noise. I tested all Watering units with the same Core2 on the same Groove port (B).</p>
<p dir="auto">There is one difference that I can tell. When I blow through the inlet of working pumps - air gets out on the other side. When I do the same on the "broken" pumps no air comes out on the other side. This makes me think there is something blocked. Its a fresh pump that I ordered a while ago so it should not have gotten any dirt in it.</p>
<p dir="auto">Is there anything I can do to get them to work? Anybody else with the same experience?</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://community.m5stack.com/topic/5145/watering-pump-does-not-work</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 01:47:21 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5145.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Mar 2023 21:40:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Watering pump does not work on Fri, 21 Jul 2023 22:07:28 GMT]]></title><description><![CDATA[<p dir="auto">If you let the kids watch you disassemble and check the impellers you might inspire a future HW engineer instead of a future SW engineer.</p>
<p dir="auto">So be careful and dont do that :)</p>
]]></description><link>https://community.m5stack.com/post/21642</link><guid isPermaLink="true">https://community.m5stack.com/post/21642</guid><dc:creator><![CDATA[mtylerjr]]></dc:creator><pubDate>Fri, 21 Jul 2023 22:07:28 GMT</pubDate></item><item><title><![CDATA[Reply to Watering pump does not work on Fri, 21 Jul 2023 15:36:27 GMT]]></title><description><![CDATA[<p dir="auto">Carefully disassemble the impeller and check it’s moving freely</p>
]]></description><link>https://community.m5stack.com/post/21635</link><guid isPermaLink="true">https://community.m5stack.com/post/21635</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 21 Jul 2023 15:36:27 GMT</pubDate></item><item><title><![CDATA[Reply to Watering pump does not work on Fri, 21 Jul 2023 13:57:27 GMT]]></title><description><![CDATA[<p dir="auto">I've the same problem :-(</p>
]]></description><link>https://community.m5stack.com/post/21634</link><guid isPermaLink="true">https://community.m5stack.com/post/21634</guid><dc:creator><![CDATA[Dario_r]]></dc:creator><pubDate>Fri, 21 Jul 2023 13:57:27 GMT</pubDate></item></channel></rss>
