<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 Stick C Plus 5V HAT output]]></title><description><![CDATA[<p dir="auto">The M5StickC-Plus is being powered through USB.</p>
<p dir="auto">The grove port is in use, connected to a temp/humidity sensor (Adafruit AHT20) and magnetometer/accelerometer sensor (Adafruit LSW303AGR).</p>
<p dir="auto">I am connecting an RS485 board (using a MAX485 IC) to the HAT pins, but the 5V output is only at 1V.</p>
<p dir="auto">Any ideas? Does the 5V output have to be enabled in code?</p>
]]></description><link>https://community.m5stack.com/topic/5146/m5-stick-c-plus-5v-hat-output</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:29:09 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5146.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Mar 2023 06:57:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 Stick C Plus 5V HAT output on Wed, 05 Apr 2023 23:32:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bazman" aria-label="Profile: bazman">@<bdi>bazman</bdi></a> Here is the StickC API link:<a href="https://docs.m5stack.com/en/api/stickc/axp192_m5stickc" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/api/stickc/axp192_m5stickc</a></p>
]]></description><link>https://community.m5stack.com/post/20535</link><guid isPermaLink="true">https://community.m5stack.com/post/20535</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Wed, 05 Apr 2023 23:32:33 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Stick C Plus 5V HAT output on Wed, 05 Apr 2023 22:39:25 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a>. Is there an API to tell what the 5V In voltage is from the HAT? I use the USB voltage to work out if the power has been cut so that I can automatically shutdown the device instead of using battery power. I wonder if this can also be done through the HAT power in...</p>
]]></description><link>https://community.m5stack.com/post/20534</link><guid isPermaLink="true">https://community.m5stack.com/post/20534</guid><dc:creator><![CDATA[bazman]]></dc:creator><pubDate>Wed, 05 Apr 2023 22:39:25 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Stick C Plus 5V HAT output on Wed, 05 Apr 2023 18:54:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bazman" aria-label="Profile: bazman">@<bdi>bazman</bdi></a> I'm sorry no one responded before.<br />
The 5V beside the GND pin is 5V always, but the 5V on the other side is 0V, because it is external 5V "in".<br />
Just tested it now and have used it many times before!</p>
]]></description><link>https://community.m5stack.com/post/20533</link><guid isPermaLink="true">https://community.m5stack.com/post/20533</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Wed, 05 Apr 2023 18:54:19 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Stick C Plus 5V HAT output on Wed, 05 Apr 2023 14:52:42 GMT]]></title><description><![CDATA[<p dir="auto">I've given up on this, now powering it direct from USB instead of HAT.</p>
]]></description><link>https://community.m5stack.com/post/20531</link><guid isPermaLink="true">https://community.m5stack.com/post/20531</guid><dc:creator><![CDATA[bazman]]></dc:creator><pubDate>Wed, 05 Apr 2023 14:52:42 GMT</pubDate></item></channel></rss>
