<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Sleep (deep&#x2F;light) causes watering unit to power on]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">i recently got an M5 Core2 and a watering unit, which I'm using for plant watering. Currently I'm using UIFlow as I didnt' find any good documentation for the watering unit using MicroPython, and UIFlow seems to be based on MicroPython anyway.</p>
<p dir="auto">As watering is something not really time-critical and I planned to operate the M5Stack using a solar power bank, I was experimenting with machine.deepsleep() and machine.lightsleep().</p>
<p dir="auto">It appeared to work for the ESP itself, however the screen stayed on, but I can at least set the brightness to 0%.</p>
<p dir="auto">The bigger issue is that both functions actually turned on the pump during the entire sleep time. How can I stop this behavior? Is there a way to power down the entire grove port during sleep?</p>
<p dir="auto">And, as a follow-up question: In case I get more watering units and connect them using a Bottom2, what do I need to do in order to avoid that the pump is switched on for those units during sleep?</p>
<p dir="auto">Thanks for your help!</p>
]]></description><link>https://community.m5stack.com/topic/5212/sleep-deep-light-causes-watering-unit-to-power-on</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 08:17:54 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5212.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 10 Apr 2023 18:25:35 GMT</pubDate><ttl>60</ttl></channel></rss>
