<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Newbie - M5Stack not running RGB code]]></title><description><![CDATA[<p dir="auto">I have downloaded the drivers and can load programs with the Arduino IDE to the ESP32 Basic Core IoT Development Kit V2.6<br />
Next step is to use the M5Flow and try to make some code run. First I wanted to get the API key, which the M5Burner-v3-beta-win-x64 did for me.<br />
Then I went to the web version of M5Flow, and following the document to load a simple RGB code had the following error in RED background:<br />
Upload code failed, maybe your device is offline check it and retry.<br />
At this point I have no idea why it will not load to the M5stack.<br />
If someone can suggest, I am listening.<br />
Thanks</p>
]]></description><link>https://community.m5stack.com/topic/5220/newbie-m5stack-not-running-rgb-code</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 13:55:21 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5220.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 Apr 2023 16:57:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Newbie - M5Stack not running RGB code on Sat, 15 Apr 2023 13:16:00 GMT]]></title><description><![CDATA[<p dir="auto">Did you select the correct core and type the correct API key into UIFlows settings?<br />
Does the API code appear in green at the bottom left of UIFlow?</p>
]]></description><link>https://community.m5stack.com/post/20607</link><guid isPermaLink="true">https://community.m5stack.com/post/20607</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 15 Apr 2023 13:16:00 GMT</pubDate></item></channel></rss>
