<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Motordriver L298N with M5core ?]]></title><description><![CDATA[<p dir="auto">It is possible to connect a L298N Motor driver on M5Stack core ?<br />
Has anyone a pin layout schema to connect pins if it is possible ?</p>
]]></description><link>https://community.m5stack.com/topic/5240/motordriver-l298n-with-m5core</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 20:41:31 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5240.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 21 Apr 2023 11:53:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Motordriver L298N with M5core ? on Sun, 23 Apr 2023 12:17:02 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a>,</p>
<p dir="auto">i try it since few days, but i can't find any information how i must connect the Motor Modul.</p>
<p dir="auto">I use this one: <a href="https://components101.com/modules/l293n-motor-driver-module" target="_blank" rel="noopener noreferrer nofollow ugc">Link</a></p>
<p dir="auto">Have you an idea how i must connect ENA (for PWM), IN1 and IN2 with the M5stack core and set the motor speed with PWM?</p>
]]></description><link>https://community.m5stack.com/post/20664</link><guid isPermaLink="true">https://community.m5stack.com/post/20664</guid><dc:creator><![CDATA[TheAlphaGhost]]></dc:creator><pubDate>Sun, 23 Apr 2023 12:17:02 GMT</pubDate></item><item><title><![CDATA[Reply to Motordriver L298N with M5core ? on Fri, 21 Apr 2023 17:09:01 GMT]]></title><description><![CDATA[<p dir="auto">The short answer is YES!<br />
Are you using a bare L298N IC, or a pre-made PCB, and if so what model number?<br />
They are very easy to program, but you need to look at the IC's pinout and understand why there are four transistors per motor.<br />
They can also control motor speed with the "ledc" PWM library.<br />
There are also L298N libraries.</p>
]]></description><link>https://community.m5stack.com/post/20659</link><guid isPermaLink="true">https://community.m5stack.com/post/20659</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Fri, 21 Apr 2023 17:09:01 GMT</pubDate></item></channel></rss>
