<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New module - SDP3x differential pressure sensor.]]></title><description><![CDATA[<p dir="auto">Would love to be able to use the M5Stack infrastructure to create a monitor for my HVAC filters to alert when it is time to change filters.</p>
]]></description><link>https://community.m5stack.com/topic/5241/new-module-sdp3x-differential-pressure-sensor</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 05:07:16 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5241.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 22 Apr 2023 01:20:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New module - SDP3x differential pressure sensor. on Tue, 21 Jan 2025 21:58:05 GMT]]></title><description><![CDATA[<p dir="auto">There's a similar request here:<br />
<a href="https://community.m5stack.com/topic/6215/product-revision-tube-air-pressure-unit-with-i2c">https://community.m5stack.com/topic/6215/product-revision-tube-air-pressure-unit-with-i2c</a></p>
]]></description><link>https://community.m5stack.com/post/27981</link><guid isPermaLink="true">https://community.m5stack.com/post/27981</guid><dc:creator><![CDATA[Maecksu]]></dc:creator><pubDate>Tue, 21 Jan 2025 21:58:05 GMT</pubDate></item><item><title><![CDATA[Reply to New module - SDP3x differential pressure sensor. on Sat, 03 Jun 2023 17:07:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bluecobras09" aria-label="Profile: bluecobras09">@<bdi>bluecobras09</bdi></a> Hi. Do you plan on programming in Arduino IDE or UIFlow (Python)? The sensor is i2c using qwiic cables and would be easy to program in Arduino, but quite a task to do in UIFlow or Python.<br />
-Terry</p>
]]></description><link>https://community.m5stack.com/post/21072</link><guid isPermaLink="true">https://community.m5stack.com/post/21072</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Sat, 03 Jun 2023 17:07:10 GMT</pubDate></item><item><title><![CDATA[Reply to New module - SDP3x differential pressure sensor. on Sat, 03 Jun 2023 08:41:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bluecobras09" aria-label="Profile: bluecobras09">@<bdi>bluecobras09</bdi></a> you need to reserch how it communicates and if there is a Micropython library for it and if not you need to learn how to create a library</p>
]]></description><link>https://community.m5stack.com/post/21070</link><guid isPermaLink="true">https://community.m5stack.com/post/21070</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 03 Jun 2023 08:41:07 GMT</pubDate></item><item><title><![CDATA[Reply to New module - SDP3x differential pressure sensor. on Fri, 02 Jun 2023 18:06:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Planning on small connections on each side of the filter to connect to the sensor itself.  Have not looked much beyond that do to time constraints.  I have ordered an SDP3x breakout from sparkfun, hoping to do some additional research soon.</p>
]]></description><link>https://community.m5stack.com/post/21056</link><guid isPermaLink="true">https://community.m5stack.com/post/21056</guid><dc:creator><![CDATA[bluecobras09]]></dc:creator><pubDate>Fri, 02 Jun 2023 18:06:22 GMT</pubDate></item><item><title><![CDATA[Reply to New module - SDP3x differential pressure sensor. on Sat, 22 Apr 2023 12:06:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bluecobras09" aria-label="Profile: bluecobras09">@<bdi>bluecobras09</bdi></a></p>
<p dir="auto">Hello.<br />
What have you researched so far in order to connect to your HVAC?</p>
]]></description><link>https://community.m5stack.com/post/20661</link><guid isPermaLink="true">https://community.m5stack.com/post/20661</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 22 Apr 2023 12:06:51 GMT</pubDate></item></channel></rss>
