<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Goplus2 with M5Stack core -&gt; Motor to slow]]></title><description><![CDATA[<p dir="auto">I have a issue with GoPlus2 and a RC Motor.</p>
<p dir="auto">If i use the motor on a raspberry with L298N Motor driver the speed ist very fast.</p>
<p dir="auto">On M5Stack core with GoPlus2 and Full Speed 100 (+127) the motor runs 1/3 of the speed from the L298N. What's the issue in M5 GoPlus2 ? Why the motor is too slow ?</p>
<p dir="auto">If i connect on the GoPlus2 a external battery with 7.4V it makes no difference.</p>
<p dir="auto">Has anyone a idea, how i can drive faster my dc motor with the GoPlus2 Modul ? It looks like the issue is "not" on motor or power voltage side. Must be on GoPlus2.</p>
]]></description><link>https://community.m5stack.com/topic/5243/goplus2-with-m5stack-core-motor-to-slow</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:04:39 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5243.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 23 Apr 2023 12:24:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Goplus2 with M5Stack core -&gt; Motor to slow on Wed, 26 Apr 2023 02:28:10 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/thealphaghost" aria-label="Profile: TheAlphaGhost">@<bdi>TheAlphaGhost</bdi></a></p>
<p dir="auto">have a look at the schematic <a href="https://docs.m5stack.com/en/module/goplus2" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>. Input voltage goes through the <em>IN Power Buck DC-DC</em> and the output is 5 V, which is used for servos and DC motors.</p>
]]></description><link>https://community.m5stack.com/post/20682</link><guid isPermaLink="true">https://community.m5stack.com/post/20682</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 26 Apr 2023 02:28:10 GMT</pubDate></item><item><title><![CDATA[Reply to Goplus2 with M5Stack core -&gt; Motor to slow on Tue, 25 Apr 2023 17:15:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thealphaghost" aria-label="Profile: thealphaghost">@<bdi>thealphaghost</bdi></a> You COULD connect the L298N using the GPIO on the side of the Core Basic?<br />
Or if you NEED the GoPlus2 could you use three of the GroveB outputs?</p>
]]></description><link>https://community.m5stack.com/post/20679</link><guid isPermaLink="true">https://community.m5stack.com/post/20679</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Tue, 25 Apr 2023 17:15:04 GMT</pubDate></item><item><title><![CDATA[Reply to Goplus2 with M5Stack core -&gt; Motor to slow on Tue, 25 Apr 2023 15:55:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thealphaghost" aria-label="Profile: thealphaghost">@<bdi>thealphaghost</bdi></a> when I tried running a 12v loco off a 12v battery I was only getting 5v out</p>
]]></description><link>https://community.m5stack.com/post/20677</link><guid isPermaLink="true">https://community.m5stack.com/post/20677</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 25 Apr 2023 15:55:55 GMT</pubDate></item><item><title><![CDATA[Reply to Goplus2 with M5Stack core -&gt; Motor to slow on Tue, 25 Apr 2023 11:25:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a></p>
<p dir="auto">WHAT? Really?!</p>
<p dir="auto">Then thats my problem! I cant find this information in the docs. It make no sense, if i can connect a external 12V Batterie…</p>
]]></description><link>https://community.m5stack.com/post/20675</link><guid isPermaLink="true">https://community.m5stack.com/post/20675</guid><dc:creator><![CDATA[TheAlphaGhost]]></dc:creator><pubDate>Tue, 25 Apr 2023 11:25:28 GMT</pubDate></item><item><title><![CDATA[Reply to Goplus2 with M5Stack core -&gt; Motor to slow on Mon, 24 Apr 2023 16:28:12 GMT]]></title><description><![CDATA[<p dir="auto">The voltage output from the go2 is only 5V</p>
]]></description><link>https://community.m5stack.com/post/20672</link><guid isPermaLink="true">https://community.m5stack.com/post/20672</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 24 Apr 2023 16:28:12 GMT</pubDate></item><item><title><![CDATA[Reply to Goplus2 with M5Stack core -&gt; Motor to slow on Mon, 24 Apr 2023 04:45:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thealphaghost" aria-label="Profile: thealphaghost">@<bdi>thealphaghost</bdi></a> OK! thanks for trying!<br />
Good luck!</p>
]]></description><link>https://community.m5stack.com/post/20670</link><guid isPermaLink="true">https://community.m5stack.com/post/20670</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Mon, 24 Apr 2023 04:45:35 GMT</pubDate></item><item><title><![CDATA[Reply to Goplus2 with M5Stack core -&gt; Motor to slow on Mon, 24 Apr 2023 04:24:14 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a></p>
<p dir="auto">128 reverse the direction from forward to backward</p>
]]></description><link>https://community.m5stack.com/post/20669</link><guid isPermaLink="true">https://community.m5stack.com/post/20669</guid><dc:creator><![CDATA[TheAlphaGhost]]></dc:creator><pubDate>Mon, 24 Apr 2023 04:24:14 GMT</pubDate></item><item><title><![CDATA[Reply to Goplus2 with M5Stack core -&gt; Motor to slow on Mon, 24 Apr 2023 01:06:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thealphaghost" aria-label="Profile: thealphaghost">@<bdi>thealphaghost</bdi></a> The MotorWriteSpeed is an int, which could be at least 255.<br />
Could you try  a number greater than +127 and see if this hack works?<br />
-Terry</p>
]]></description><link>https://community.m5stack.com/post/20668</link><guid isPermaLink="true">https://community.m5stack.com/post/20668</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Mon, 24 Apr 2023 01:06:42 GMT</pubDate></item></channel></rss>
