<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Charging problem CoreInk]]></title><description><![CDATA[<p dir="auto">Hello!<br />
I have a problem with my CoreInk: I cannot charge the battery through USB and I cannot upload my code in the CoreInk powered through USB.<br />
If I want to upload a code in CoreInk with IDE Arduino, I need to plug the battery in it and the battery doesn't charge with USB. To charge the battery, I need to plug another supply by a 5V IN below the CoreInk. The LED of charge is OFF when I plug USB but ON when I supply with below port. Does someone have an idea of why I have this problem, and what is the cause of that?<br />
Thanks in advance<br />
Lemiaourapide</p>
]]></description><link>https://community.m5stack.com/topic/5245/charging-problem-coreink</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 05:37:22 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5245.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 23 Apr 2023 09:46:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Charging problem CoreInk on Tue, 25 Apr 2023 07:20:28 GMT]]></title><description><![CDATA[<p dir="auto">have you tried to use different usb port/cable?</p>
]]></description><link>https://community.m5stack.com/post/20674</link><guid isPermaLink="true">https://community.m5stack.com/post/20674</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Tue, 25 Apr 2023 07:20:28 GMT</pubDate></item></channel></rss>
