<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[COM.LTE Module not responding]]></title><description><![CDATA[<p dir="auto">Using this module with an external power supply along with the Core 2. No other modules attached at the moment.<br />
<a href="https://shop.m5stack.com/products/com-lte-modulesim7600g" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/com-lte-modulesim7600g</a></p>
<p dir="auto">Only code uploaded is the example provided on uiflow, but i cant get any sort of response. The only output i get is "Text" in the top left of the screen. The program seems to hang during init and never makes it past that point. Confirmed DC power switch is on the correct setting, as well as the tx/rx dip switches.</p>
<p dir="auto">Flashing the easyloader results in no output to the screen, as well as a high pitched ringing from the modem</p>
<p dir="auto">Setting COM.X to true on m5burner gives the error 'module stable timeout'</p>
<hr />
from m5stack_ui import *<br />
from uiflow import *<br />
from comx.lte import LTE</p>
<p dir="auto">screen = M5Screen()<br />
screen.clean_screen()<br />
screen.set_screen_bg_color(0xFFFFFF)</p>
<p dir="auto">resp = None</p>
<p dir="auto">label0 = M5Label('label0', x=33, y=36, color=0x000, font=FONT_MONT_14, parent=None)<br />
label1 = M5Label('label1', x=37, y=63, color=0x000, font=FONT_MONT_14, parent=None)<br />
label2 = M5Label('label2', x=35, y=91, color=0x000, font=FONT_MONT_14, parent=None)<br />
label3 = M5Label('label3', x=36, y=114, color=0x000, font=FONT_MONT_14, parent=None)</p>
<p dir="auto">lte = LTE(tx=13, rx=5)<br />
label0.set_text(str(lte.check_status()))<br />
label1.set_text(str(lte.get_single_quality()))<br />
label2.set_text(str(lte.get_network_registration()))<br />
label3.set_text(str(lte.get_gprs_network_registration()))<br />
while True:<br />
if str((lte.get_gprs_network_registration())) == '1':<br />
# echo "test"<br />
resp = lte.http_get('<a href="http://www.m2msupport.net/m2msupport/test.php" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.m2msupport.net/m2msupport/test.php</a>')<br />
if resp:<br />
label4.set_text(str(resp[1]))<br />
wait_ms(2)</p>
]]></description><link>https://community.m5stack.com/topic/5256/com-lte-module-not-responding</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 15:16:08 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5256.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 29 Apr 2023 03:04:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to COM.LTE Module not responding on Tue, 02 May 2023 11:59:19 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/jkeyser" aria-label="Profile: jkeyser">@<bdi>jkeyser</bdi></a></p>
<p dir="auto">that is great to hear. Thank you for reporting back.</p>
]]></description><link>https://community.m5stack.com/post/20735</link><guid isPermaLink="true">https://community.m5stack.com/post/20735</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 02 May 2023 11:59:19 GMT</pubDate></item><item><title><![CDATA[Reply to COM.LTE Module not responding on Tue, 02 May 2023 00:23:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a><br />
Thanks, while looking into that I found i wasn't also unable to open any sort of connection to send AT commands. Turns out i misunderstood the dip settings for the core 2. Set to 16/17 on the modem and 14/13 on uiflow init and i have communication now.</p>
]]></description><link>https://community.m5stack.com/post/20729</link><guid isPermaLink="true">https://community.m5stack.com/post/20729</guid><dc:creator><![CDATA[jkeyser]]></dc:creator><pubDate>Tue, 02 May 2023 00:23:02 GMT</pubDate></item><item><title><![CDATA[Reply to COM.LTE Module not responding on Mon, 01 May 2023 08:11:42 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/jkeyser" aria-label="Profile: jkeyser">@<bdi>jkeyser</bdi></a></p>
<p dir="auto">have a look at this <a href="https://community.m5stack.com/topic/4626/cat-m-or-catm-gnss-unit-not-working-in-uiflow-screen-stays-blank-solved/3">post</a>. It's not the same module, but I suspect the initialization process, e.g. checking for a SIM PIN, is the same.</p>
]]></description><link>https://community.m5stack.com/post/20722</link><guid isPermaLink="true">https://community.m5stack.com/post/20722</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 01 May 2023 08:11:42 GMT</pubDate></item></channel></rss>
