<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Neopixel voltage?]]></title><description><![CDATA[<p dir="auto">For the A035 (<a href="https://docs.m5stack.com/en/unit/neopixel" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/unit/neopixel</a>), what voltages should I use if I''m not using the grove connector, both for power and signal? I've seen some indication that maybe 5v for power is needed; would connecting a 3.3 signal work in that case? Don't want to let out the magic smoke!</p>
<p dir="auto">From <a href="https://cdn-shop.adafruit.com/product-files/1138/SK6812+LED+datasheet+.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">https://cdn-shop.adafruit.com/product-files/1138/SK6812+LED+datasheet+.pdf</a>, it looks like--with a 5V supply--Vih is 3.4V, and 3.3V isn't going to hit that. But all those are "typical".</p>
]]></description><link>https://community.m5stack.com/topic/5278/neopixel-voltage</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 22:33:51 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5278.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 May 2023 00:20:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Neopixel voltage? on Mon, 08 May 2023 04:20:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dclaar" aria-label="Profile: dclaar">@<bdi>dclaar</bdi></a> I have no problem with the Stamp-PICO running on the 3.3V power from the programmer.<br />
And the StampS3 running on USB 5V actually outputs out 3.3V at the RGB output...<br />
So, YES!</p>
]]></description><link>https://community.m5stack.com/post/20784</link><guid isPermaLink="true">https://community.m5stack.com/post/20784</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Mon, 08 May 2023 04:20:02 GMT</pubDate></item></channel></rss>
