<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[No COM found (Soft Bricked)]]></title><description><![CDATA[<p dir="auto">Hi guys,</p>
<p dir="auto">I have an M5Stack Core2. I wrote a little program to it an run it for about 9 months. Now I wanted to adjust my code. Maybe translate it to micropython etc.<br />
However, my computer can't identify the M5Stack anymore. Which means, I get no COM to use M5burner or Arduino IDE with. I tried to plug-in another m5stack, and it detects the COM Port on that one. But not mine. Therefore I cant use m5burner to reset the device. Is there any other possibility? I've seen in this post <a href="https://community.m5stack.com/topic/4176/m5stack-core-2-appears-to-be-bricked/4">https://community.m5stack.com/topic/4176/m5stack-core-2-appears-to-be-bricked/4</a> that there doesn't seem to be any hardware button for it. Any other possibilities to factory reset?</p>
<p dir="auto">Thanks in advance and greetings,<br />
Raeph</p>
]]></description><link>https://community.m5stack.com/topic/5298/no-com-found-soft-bricked</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 12:22:19 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5298.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 13 May 2023 10:44:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to No COM found (Soft Bricked) on Fri, 19 May 2023 16:46:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Sadly didn't get it to work so far... But thanks anyways :-)</p>
]]></description><link>https://community.m5stack.com/post/20898</link><guid isPermaLink="true">https://community.m5stack.com/post/20898</guid><dc:creator><![CDATA[raeph]]></dc:creator><pubDate>Fri, 19 May 2023 16:46:51 GMT</pubDate></item><item><title><![CDATA[Reply to No COM found (Soft Bricked) on Wed, 17 May 2023 21:23:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Awesome thank you. I'll try that</p>
]]></description><link>https://community.m5stack.com/post/20876</link><guid isPermaLink="true">https://community.m5stack.com/post/20876</guid><dc:creator><![CDATA[raeph]]></dc:creator><pubDate>Wed, 17 May 2023 21:23:03 GMT</pubDate></item><item><title><![CDATA[Reply to No COM found (Soft Bricked) on Sun, 14 May 2023 07:09:31 GMT]]></title><description><![CDATA[<p dir="auto">Hold the power button on, connect the usb cable, click the "Erase button" and then release the power button once its stats connecting.<br />
Removing the base and battery helps.</p>
<p dir="auto">It takes practice to get it to work as it is know as a "Soft Brick" and I have done it myself.<br />
The issue is that you need to get the computer to connect before the boot loader starts and that is a very tiny timeframe to hit.</p>
]]></description><link>https://community.m5stack.com/post/20845</link><guid isPermaLink="true">https://community.m5stack.com/post/20845</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 14 May 2023 07:09:31 GMT</pubDate></item><item><title><![CDATA[Reply to No COM found (Soft Bricked) on Sat, 13 May 2023 19:56:43 GMT]]></title><description><![CDATA[<p dir="auto">But how can I use M5Burner if its not able to connect to the core2? I can't reach it via com port and the program was flashed via Arduino ide. So there's no wifi etc. activated.<br />
I updated the software several times without problems. Idk why it's not working anymore right now.</p>
]]></description><link>https://community.m5stack.com/post/20844</link><guid isPermaLink="true">https://community.m5stack.com/post/20844</guid><dc:creator><![CDATA[raeph]]></dc:creator><pubDate>Sat, 13 May 2023 19:56:43 GMT</pubDate></item><item><title><![CDATA[Reply to No COM found (Soft Bricked) on Sat, 13 May 2023 19:47:11 GMT]]></title><description><![CDATA[<p dir="auto">Try using M5Burner to wipe the Core2.<br />
What you are describing is a user created bug that blocks the port from communicating with the computer.<br />
It takes timing and practice but you can reset the Core2 and wipe the existing program.<br />
Check your code to make sure it is not writing to the ports pins.</p>
]]></description><link>https://community.m5stack.com/post/20843</link><guid isPermaLink="true">https://community.m5stack.com/post/20843</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 13 May 2023 19:47:11 GMT</pubDate></item></channel></rss>
