<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[BTC 2.0 not powering the basic M5Stack]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I've just bought a base BTC 2.0, including the DHT12 sensor, but when I connect it to my M5Stack Basic (Black) version it does not power it, I have checked that there is 5V on the 5V pins on the M5Stack rear PCB.</p>
<p dir="auto">Should it power the M5Stack Basic?</p>
]]></description><link>https://community.m5stack.com/topic/531/btc-2-0-not-powering-the-basic-m5stack</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:48:40 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/531.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 23 Jan 2019 08:14:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to BTC 2.0 not powering the basic M5Stack on Tue, 29 Jan 2019 06:27:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus" aria-label="Profile: lukasmaximus">@<bdi>lukasmaximus</bdi></a> said in <a href="/post/2763">BTC 2.0 not powering the basic M5Stack</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gadjet" aria-label="Profile: gadjet">@<bdi>gadjet</bdi></a> sorry this was definitely an issue with the description. The btc ticker is not capable of charging the m5 stack.</p>
<p dir="auto">I wouldn't mind but I bought two of them !!! Oh well back to my 3D printed stand and a big battery.</p>
]]></description><link>https://community.m5stack.com/post/2764</link><guid isPermaLink="true">https://community.m5stack.com/post/2764</guid><dc:creator><![CDATA[gadjet]]></dc:creator><pubDate>Tue, 29 Jan 2019 06:27:42 GMT</pubDate></item><item><title><![CDATA[Reply to BTC 2.0 not powering the basic M5Stack on Tue, 29 Jan 2019 06:24:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gadjet" aria-label="Profile: gadjet">@<bdi>gadjet</bdi></a> sorry this was definitely an issue with the description. The btc ticker is not capable of charging the m5 stack.</p>
]]></description><link>https://community.m5stack.com/post/2763</link><guid isPermaLink="true">https://community.m5stack.com/post/2763</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Tue, 29 Jan 2019 06:24:37 GMT</pubDate></item><item><title><![CDATA[Reply to BTC 2.0 not powering the basic M5Stack on Sun, 27 Jan 2019 19:59:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a> said in <a href="/post/2731">BTC 2.0 not powering the basic M5Stack</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gadjet" aria-label="Profile: gadjet">@<bdi>gadjet</bdi></a><br />
You can charge core just plugging usb cable to core, don't need BTC. BTC does not own any charging IC like IP5306.</p>
<p dir="auto">My assumption from the product info (which they say was an error) stated that it was a charging base, it wouldn't need an IP5306 it just needed to put 5V onto the same 5V rail that comes from the USB socket on the side of the core.</p>
<p dir="auto">The label on the connector says 5V but it's not the same 5V that comes from the USB on the core!!<br />
<img src="https://www.dropbox.com/s/nsf1hyfnsxej639/m5stackbase.jpg?dl=1" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/2737</link><guid isPermaLink="true">https://community.m5stack.com/post/2737</guid><dc:creator><![CDATA[gadjet]]></dc:creator><pubDate>Sun, 27 Jan 2019 19:59:17 GMT</pubDate></item><item><title><![CDATA[Reply to BTC 2.0 not powering the basic M5Stack on Sun, 27 Jan 2019 15:07:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gadjet" aria-label="Profile: gadjet">@<bdi>gadjet</bdi></a><br />
]]></description><link>https://community.m5stack.com/post/2731</link><guid isPermaLink="true">https://community.m5stack.com/post/2731</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Sun, 27 Jan 2019 15:07:49 GMT</pubDate></item><item><title><![CDATA[Reply to BTC 2.0 not powering the basic M5Stack on Fri, 25 Jan 2019 13:47:22 GMT]]></title><description><![CDATA[<p dir="auto">OK I tried to connect the USB cable once the internal battery was flat and it does indeed power up the M5Stack, the operation seems different to plugging it into the USB socket on the side of the M5Stack.</p>
]]></description><link>https://community.m5stack.com/post/2694</link><guid isPermaLink="true">https://community.m5stack.com/post/2694</guid><dc:creator><![CDATA[gadjet]]></dc:creator><pubDate>Fri, 25 Jan 2019 13:47:22 GMT</pubDate></item><item><title><![CDATA[Reply to BTC 2.0 not powering the basic M5Stack on Fri, 25 Jan 2019 13:35:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a> No, it works fine if I connect the USB directly to the side of the Stack.</p>
]]></description><link>https://community.m5stack.com/post/2693</link><guid isPermaLink="true">https://community.m5stack.com/post/2693</guid><dc:creator><![CDATA[gadjet]]></dc:creator><pubDate>Fri, 25 Jan 2019 13:35:21 GMT</pubDate></item><item><title><![CDATA[Reply to BTC 2.0 not powering the basic M5Stack on Fri, 25 Jan 2019 11:10:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gadjet" aria-label="Profile: gadjet">@<bdi>gadjet</bdi></a><br />
Maybe the battery of Basic is dead. You need to charge it.</p>
]]></description><link>https://community.m5stack.com/post/2691</link><guid isPermaLink="true">https://community.m5stack.com/post/2691</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Fri, 25 Jan 2019 11:10:42 GMT</pubDate></item><item><title><![CDATA[Reply to BTC 2.0 not powering the basic M5Stack on Thu, 24 Jan 2019 18:59:47 GMT]]></title><description><![CDATA[<p dir="auto">So anybody got one of these bases and it works?<br />
<a href="https://www.aliexpress.com/store/product/M5Stack-New-BTC-Ticker-DHT12-Digital-Humidity-Temperature-Sensor-ESP32-for-Micropython-Bitcoin-Price-Ticker-with/3226069_32852302770.html?spm=a2g1y.12024536.productList_12432753.pic_7" target="_blank" rel="noopener noreferrer nofollow ugc">Base</a></p>
]]></description><link>https://community.m5stack.com/post/2681</link><guid isPermaLink="true">https://community.m5stack.com/post/2681</guid><dc:creator><![CDATA[gadjet]]></dc:creator><pubDate>Thu, 24 Jan 2019 18:59:47 GMT</pubDate></item></channel></rss>
