<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Need help to fix Error M5GO]]></title><description><![CDATA[<p dir="auto">Hello, I have a small problem. I cannot connect Wi-Fi. it shows message error.</p>
<p dir="auto">Wait COM.X module connect and stable :) (TX : 13 RX:5)<br />
Wait module stable timeout. Please check module connect :(<br />
but I don't have module connected. I try to go back on set up. so, I press button many times, but it does not work.</p>
<p dir="auto"><img src="/assets/uploads/files/1685706297825-img_6867.jpeg" alt="0_1685706304253_IMG_6867.jpeg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/5349/need-help-to-fix-error-m5go</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:45:27 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5349.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 Jun 2023 11:46:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Need help to fix Error M5GO on Fri, 02 Jun 2023 14:59:25 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/toonny" aria-label="Profile: toonny">@<bdi>toonny</bdi></a></p>
<p dir="auto">try using M5Burner to either erase flash first or use the <code>Configure</code> button to disable LTE usage.</p>
]]></description><link>https://community.m5stack.com/post/21053</link><guid isPermaLink="true">https://community.m5stack.com/post/21053</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 02 Jun 2023 14:59:25 GMT</pubDate></item></channel></rss>
