<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ATOM S3 Lite: Device is red in UIFlow 2.0, i cant run or download programm to it]]></title><description><![CDATA[<p dir="auto">I burn my Atom S3 Lite in m5 burner with official firmware (Alpha-15 version). The burn process completed successfully, and bind device to my account. After that I open Uiflow 2.0, enter to my account, press ''select device" and select my public device. But the selected device is displayed in red and when I click "Run" or "Download" it writes an error "Execute code failed!". What am I doing wrong?</p>
]]></description><link>https://community.m5stack.com/topic/5352/atom-s3-lite-device-is-red-in-uiflow-2-0-i-cant-run-or-download-programm-to-it</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 15:50:34 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5352.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 Jun 2023 16:30:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ATOM S3 Lite: Device is red in UIFlow 2.0, i cant run or download programm to it on Sat, 03 Jun 2023 10:08:41 GMT]]></title><description><![CDATA[<p dir="auto">Thank you! As it turned out, the main problem was that if in a program on UIFlow 2.0 (block mode) you create a variable named "state" and assign it 0 during initialization, then the controller starts to behave inappropriately (hangs, new programs either do not load or load but do not work , there are problems described in the previous post). It only helps to re-flash the controller using M5Burner and load into it a program in which there are no omissions of a variable called "state".</p>
]]></description><link>https://community.m5stack.com/post/21071</link><guid isPermaLink="true">https://community.m5stack.com/post/21071</guid><dc:creator><![CDATA[zotovan]]></dc:creator><pubDate>Sat, 03 Jun 2023 10:08:41 GMT</pubDate></item><item><title><![CDATA[Reply to ATOM S3 Lite: Device is red in UIFlow 2.0, i cant run or download programm to it on Sat, 03 Jun 2023 07:30:13 GMT]]></title><description><![CDATA[<p dir="auto">You device is not connected to your local network or it has failed to connect to the UIFLow server.<br />
Open M5Burner, open config and check your SSID and password are correct.</p>
]]></description><link>https://community.m5stack.com/post/21066</link><guid isPermaLink="true">https://community.m5stack.com/post/21066</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 03 Jun 2023 07:30:13 GMT</pubDate></item></channel></rss>
