<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Tough external power button]]></title><description><![CDATA[<p dir="auto">Hello everybody!<br />
Has anyone tried to install an external on/off button on the Tough yet (using the additional hole in the case, for example)? Is it possible?</p>
<p dir="auto">I've tried searching the forum, but haven't found anything.</p>
<p dir="auto">Thanks in advance for the help,<br />
Diego</p>
]]></description><link>https://community.m5stack.com/topic/5390/m5tough-external-power-button</link><generator>RSS for Node</generator><lastBuildDate>Wed, 06 May 2026 04:49:24 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5390.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Jun 2023 16:06:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Tough external power button on Wed, 14 Jun 2023 20:27:41 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/dichi" aria-label="Profile: dichi">@<bdi>dichi</bdi></a></p>
<p dir="auto">if I needed a external power button for the M5Tough I'd solder a thin wire to GND and another to the existing power button; then connect the two wires to the external power button.</p>
<p dir="auto"><img src="/assets/uploads/files/1686774453121-m5toughpowerbutton_20230614.png" alt="0_1686774460520_M5ToughPowerButton_20230614.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Optionally you could drill a hole into the base where the existing power button is. (You'd loose some water proofing I guess.)</p>
]]></description><link>https://community.m5stack.com/post/21203</link><guid isPermaLink="true">https://community.m5stack.com/post/21203</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 14 Jun 2023 20:27:41 GMT</pubDate></item></channel></rss>
