<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 Atom Lite BT MAC]]></title><description><![CDATA[<p dir="auto">I am new, and need a way to acquire the mac of the BT on the Atom Lite.<br />
Anyone have a sketch that will do that ?</p>
<p dir="auto">I have a sketch, but it requires a file, not found on the Master files list.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/topic/5413/m5-atom-lite-bt-mac</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 13:06:21 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5413.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 23 Jun 2023 22:14:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 Atom Lite BT MAC on Sat, 24 Jun 2023 02:19:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/starlog" aria-label="Profile: starlog">@<bdi>starlog</bdi></a> In Arduino IDE it is easy to do:<br />
upload any sketch and the check the upload stream  (the bottom of the IDE) by scrolling back up to the start.</p>
<pre><code>Sketch uses 243709 bytes (7%) of program storage space. Maximum is 3145728 bytes.
Global variables use 19348 bytes (5%) of dynamic memory, leaving 308332 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.5.1
Serial port /dev/cu.usbmodem101
Connecting...
Chip is ESP32-S3 (revision v0.1)
Features: WiFi, BLE
Crystal is 40MHz
MAC: 68:b6:b3:22:4c:6c
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
etc.
]]></description><link>https://community.m5stack.com/post/21294</link><guid isPermaLink="true">https://community.m5stack.com/post/21294</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Sat, 24 Jun 2023 02:19:11 GMT</pubDate></item></channel></rss>
